Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 05-23-2007, 09:22 PM   #1
Sparkygus
Sparkygus's Avatar
Profile:  2007 25' International CCD FB
Laguna Niguel , California
Buck rivets or Olympic rivets?
We recently posted about our AS being vandalized. We now have estimates from C&G. One estimate is using the buck rivets for $2,705.79 to replace the rear segment #28, and the other estimate is for $1,998.67 using the olympic loc rivets. Since we are submitting a claim for this to the responsible party, which rivet is preferable? There is a big difference in cost. Is there a big difference in the look, or the quality? This is for a 2007 International.
Sparkygus is offline   Reply With Quote
Old 05-23-2007, 09:26 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
I would go with the bucked rivets if it's on someone else's nickel...they are better and how the factory built it originally. However, (big "BUT" coming...) they will most likely have to remove some inside panels to do it right so it might be too invasive...and ultimately cause more "issues" to live with on the inside. C & G has a great reputation for this sort of work, so I think you are in good hands either way.
We have a replaced panel on our GlobeTrotter (by PO) with olympic rivets and most can't tell or don't notice until it's pointed out. Heck, we didn't know for the first 18 months we owned it ~
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 05-23-2007, 09:49 PM   #3
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
If they buck you have to remove the interior skin. Go that route if the insurance will go for it. Supposedly not much difference in strength but it does look much better up close.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 11-06-2008, 10:19 PM   #4
VintageRV
Vintage Trailer Supply
Commercial Vendor
VintageRV's Avatar
Profile:  1956 22' Caravanner
Montpelier , Vermont
I realize this is an old thread and the insurance is long paid, but I thought I'd add my 2 cents.
We sell a LOT of Olympic Bulb-Tite Rivets, so you might not expect me to say this, but I'd absolutely use buck rivets if cost is not an issue. Buck rivets are stronger. In practical terms, you'll probably never have a problem with Olympic rivets, but the shear strength is many times greater on a buck rivet (approx 16000 psi) than on the Olympic Bulb-Tite (350 psi).
I realize the 16000 psi is complete overkill, but it points to a significant difference between the two.
Steve Hingtgen WBCCI #2669
http://www.vintagetrailersupply.com
800-644-4620
VintageRV is offline   Reply With Quote
Old 11-06-2008, 11:27 PM   #5
Alumanutz
Alumanutz's Avatar
Profile:  1966 22' Safari
Chico , California
If anybody has doubts, please look at my blog. I am now in the process of removing all of the interior skins to replace the Olympics. There are photos of how the center of the Olympic falls out and the you have an instant water leak. I would never use Olympics for anything structural. Airstream did not use them when they built it and I won't when I restore it.
NUTZ
View my Airstream Blog at www.alumanutz.blogspot.com
Grown men, dressed as clowns, concern me.
Alumanutz is online now   Reply With Quote
Old 11-07-2008, 12:15 AM   #6
custom67as
Profile:  1967 22' Safari
Deer Park , Washington
I have put about 100 of the Olympic rivets in my Airstream and another 100 in my 55 Boles-Aero so far and I'm not done with it. The Airstream has had them in for 2 years and I have not had any trouble. I caulked every blessed one though and maybe that's the difference. The only time I had holes was while installing the rivets. For some strange reason the center comes out while installing them every now and then. Then I have to drill them out and try again. No matter what rivet one uses, you better caulk them or you will be asking for trouble. It's a pain to do but better to be safe than sorry later.
Ralph
custom67as is offline   Reply With Quote
Old 11-07-2008, 04:03 AM   #7
62overlander
not the shiniest rivet
Commercial Vendor
62overlander's Avatar
Profile:  1962 26' Overlander
1966 26' Overlander
Catonsville , Maryland
This topic sure does come out a lot... Serious kudos to Steve for being honest and not just promoting what he sells.
BUCK THEM!
read my blog at: http://annalumanum.blogspot.com/ or view my photos at: http://picasaweb.google.com/dadofava1966/AnnaLumanum02
WBCCI, VAC, WDCU#7183
62overlander is offline   Reply With Quote
Old 11-07-2008, 12:14 PM   #8
ts8501
ts8501's Avatar
Profile:  1990 34' Excella
1964 22' Safari
Savage , Minnesota
Can someone comment on what should be used when they replace the belly pan?
ts8501 is offline   Reply With Quote
Old 11-07-2008, 12:40 PM   #9
crispyboy
crispyboy's Avatar
Profile:  1981 22' Excella II
alexandria , Kentucky
ts8501,
I put my belly pan back on with these large flanged rivits. They work great.
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
crispyboy is offline   Reply With Quote
Old 11-07-2008, 12:51 PM   #10
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
Thumbs up
Originally Posted by crispyboy View Post
ts8501,
We used the same.
Shari
Old 11-07-2008, 02:34 PM   #11
ts8501
ts8501's Avatar
1964 22' Safari
Savage , Minnesota
Perfect, thanks!
Old 11-10-2008, 09:30 AM   #12
VintageRV
Commercial Vendor
VintageRV's Avatar
I don't want to leave an impression that Olympic rivets are poor quality. They are excellent and there are hundreds of thousands of them in use on Airstreams at this very moment. They're just not aircraft-grade structural rivets. They're all you need for almost any repair, but when you're finished, you may not want to fly your Airstream at 30000 feet.
800-644-4620
Old 11-19-2008, 03:46 PM   #13
Airstray
Airstray
Airstray's Avatar
Profile:  1966 26' Overlander
Shelton , Washington
Images: 8
Can someone explain the difference between Olympic rivets and the aluminum rivets sold everywhere? Airstray
Airstray is offline   Reply With Quote
Old 11-19-2008, 04:24 PM   #14
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
This older thread might help...specifically these pictures.
Basically there are three different kinds of rivets:
  • Bucked Rivets - Solid and strong - BUT, you must have access to both sides of the rivet in order to install them. Also, in most cases, a second person to help install them. These are the kind that were originally used on your Airstream exterior.
  • Olympic Rivets - three legged with heads that look like solid bucked rivets, if they are shaved properly - can be installed w/o removing interior panels. These are often used as replacements for bucked rivets when you don't want to or can't dismantled your entire interior to access the back side of the panels being riveted. Not as strong as bucked but strong enough for most small repair projects and/or non-structural uses.
  • Pop Rivets - the kind you can get at the hardware store, they have a stem & hole in the center - can also be installed w/o removing panels but were only used on the interiors of Airstreams. They aren't nearly as strong as the other two types.
Shari
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 38 08-13-2008 03:31 PM
Olympic rivets JPAIRSTREAM Ribs, Skins & Rivets 2 09-30-2002 08:21 PM
Rivets and Karma Joan D'Andrea Our Community 4 09-19-2002 08:43 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 07:07 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 04:02 PM
test
