Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 05-05-2003, 11:42 AM   #1
Randy Johnson
Randy Johnson's Avatar
Profile:
Brushed Surface Help
'98 Bambi
I am trying to repair a dent in one rear panel and after repairing and stripping the clearcoat I want to get the surface back to the original brushed surface as close as possible. I've heard any sanding or scotchbrite is a NO-NO. Is there any technic that will get it close?
Thanks for any help! Randy
Randy Johnson is offline   Reply With Quote
Old 05-05-2003, 05:20 PM   #2
j54mark
Profile:
I don't think so. Certainly none I've ever heard of.
Why strip the clearcoat? And if it is necessary, why not have that panel recoated - in other words, why do you need to deal with the metal surface at all?
Mark
Old 05-05-2003, 05:57 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Surface finish.
The surface of the metal is not a brushed finish.
It is a "mill finish."
Sanding a scratch or dent, WILL, make that area more noticeable.
Then the cost really escalates.
Don't believe it? Try it on a sample of the same metal, and look at it from different angles.
0000 steel wool doesn't solve the problem either.
inlandrv.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Finally, got started ~ 53flyingcloud Cleaning, Stripping & Polishing 506 06-24-2008 01:57 PM
Brushed aluminum? 69Ambassador Ribs, Skins & Rivets 7 10-21-2003 05:15 PM
Protect your new polished A/S 53flyingcloud Cleaning, Stripping & Polishing 20 08-19-2003 09:16 PM
Fixing a scratch on a brushed finish? acwdgw Cleaning, Stripping & Polishing 3 10-22-2002 02:27 PM
polish a brushed trailer? john hd Cleaning, Stripping & Polishing 6 08-25-2002 11:03 PM
test
