Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 05-30-2005, 02:19 PM   #1
Kistler
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
Broken rivet holding compartment door restraint?
One of my compartments has a broken rivet head which held the cable restraint when the door is open.....One side still is holding.
Any ideas on how to repair this? Maybe a tiny screw into the rivet--or what's left of it--to hold the cable......
I don't rivet, nor do I solder.
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 05-30-2005, 02:26 PM   #2
rluhr
Commercial Vendor
rluhr's Avatar
Profile:  1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Kistler, putting in a replacement pop rivet is the easiest thing in the world. Drill out the remains of the old rivet with a 1/8" drill. Then with an inexpensive rivet tool found at Sears or any tool store and a box of POP rivets found at hardware stores, you can replace it.
It's worth learning how to do this. It's easy and kind of fun. Changing a rivet need be not much harder than changing a light bulb.
WBCCI #9990 | VAC | Full-timer | AIRSTREAM LIFE magazine | Tour of America weblog
rluhr is offline   Reply With Quote
Old 05-30-2005, 02:29 PM   #3
Kistler
Kistler's Avatar
I'd try it but.....the door seems to be hollow. How do I get the rivet behind the skin on the inside of the door? The rivet doesn't go through to the outside trailer skin?????
Kistler
Old 05-30-2005, 09:05 PM   #4
rluhr
Commercial Vendor
rluhr's Avatar
2005 30' Safari
The rivet does that for you automatically. You just shove the rivet into the hole you made (the same hole the original rivet was in, before you drilled it out), and the rivet tool causes the backside of the rivet (which will be inside the door) to deform, making it pull tight to the metal.
It sounds complicated but it isn't. It's as easy as hammering in a nail. Buy the pop rivet tool and ask the salesperson to demo it for you. Just seeing it done once is enough to give you the idea.
Old 05-30-2005, 09:15 PM   #5
Kistler
Kistler's Avatar
Thank you, Sir. It really helps me to tell you guys my problems.
Kistler
replacing compartment locks Dave Cole Exterior Storage Compartments & Access Doors 3 08-14-2008 07:34 PM
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 38 08-13-2008 02:31 PM
Storage Compartment Locks Jim Clark 1968 Globetrotter 13 06-25-2006 07:40 PM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Holding tank valve pull's camphost Waste Systems, Tanks & Totes 3 10-31-2002 11:11 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
