Old 06-11-2012, 08:55 AM   #1
2012 25' Flying Cloud
Golden , Colorado
Body shops in Denver area?
I have the first "wound" in my 2012 Airstream (25' flying cloud). Clipped an aspen tree and pulled rear awning bracket clean off. It pulled the screws and buckled the skin at the mount sites. Huge bummer! I called Windish and they can't even look at it until July 17th. I plan on siliconing the mount holes and the seams where the rivits poped out so I can use it for now. But, I'd like to get it in somewhere more quickly. Any ideas? Suggestions?
CBabbs is offline   Reply With Quote
Old 06-11-2012, 09:42 AM   #2
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Check with Timeless Travel Trailers and see if they can help you. They apparently do excellent work.
www.timelesstraveltrailers.com/
Intermountain Coach in Colorado Springs used to sell Airstreams and may still service them.
Intermountain Coach New Used RV Bus Car Dealer Colorado Springs Denver
The accepted doctrine says not to use silicone sealer on the Airstream aluminum. I am sure someone will suggest something better for you. If that panel needs to be replaced, it won't hurt, but if not, it apparently discolors the Aluminum.
Ken
Old 06-11-2012, 09:45 AM   #3
1974 Argosy 20
Kooskia , Idaho
If you do a temporary repair, I would suggest you use something other than silicone, as it is difficult to remove when the final repair is done.
Old 06-11-2012, 11:37 AM   #4
Golden , Colorado
Thanks for the info! I called Timeless and they are willing to look at it. It seems they do mostly custom work though.
Anyone have a suggestion other than silicone to temporarily seal the mount holes and seam?
Thanks!
Old 06-11-2012, 12:30 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Unhappy Sorry to hear of your mishap...
DON'T use silicone! Use aluminum tape (not duct tape) instead - we always have a roll in our travel tool box.
As others have stated, silicone is a no-no on Airstreams.
Shari
Old 06-11-2012, 12:41 PM   #6
Ag&Au's Avatar
Thanks!
Here are some candidates in this thread:
http://www.airforums.com/forums/f456...ler-87089.html
Airstream store has this available:
https://store.airstream.com/product_...roducts_id=603
Ken
