05-12-2009, 10:52 AM
1967 24' Tradewind
Greenville
, South Carolina
Best drill for rivet removal?
I've done a search and can't seem to locate what RPM drill is suggested for drilling out rivets. I've read here somewhere that a pneumatic drill is suggested for the faster RPM. How fast is suggested, where to purchase and how much should I expect to spend? In the few catalogues (Craftsman, Northern Tool, Etc.) that I have checked, the speed 1800 is very close to my electric drill. Still think it would be great if there were a forum listing dedicated to tools!
05-12-2009, 11:01 AM
2006 28' Safari SE
Colorado Springs
I don't have my notes with me from the vintage restoration rally but you're on the right track. You don't want to use a battery powered drill. Pneumatic or plug in electric are recommended and I believe the RPM was 3600 +. I'm sure one of the vintage guys can be more precise.
-Ken
4CU Charter Member
Corona
The higher the speed, the better the job, certainly at least 15,000 RPM.
We use 25,000 to 30,000 RPM drill motors.
They work with feather touch pressure, and when used properly, they don't create any burrs.
Chicago Pneumatic makes several different high speed drill motors.
05-12-2009, 11:54 AM
More than one rivet loose
Los Alamos
, New Mexico
An Aviation tool supply house is your best best.
Browns or Aircraft Tool Supply. You will need an automatic center punch as well. The drill bit will walk off the rivet head so quickly you will not be able to catch it before it damages the skin.
Michelle TAC MT-0
Sarah, Snowball
05-12-2009, 12:06 PM
1967 24' Tradewind
Greenville
, South Carolina
Now there's a new one to me, an automatic center punch. Thanks for the tips!
05-12-2009, 01:01 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
As DIY'rs we were not interested in buying every specialized tool out there "just because". Not saying we didn't buy a bunch of new tools...but we just used a standard electric (not battery) drill without any problems on the rivets. Another tip is we found if you took the drill bit and by hand, reverse turned it a 1/4 to 1/2 turn or so before drilling each solid/Olympic rivet, you didn't need to center punch every one - it set the bit so it wouldn't wander. Actually, our trailer's solid rivets had little dimples at the center anyways so those helped also. Pop rivets don't need center punching either - you just drill in the stem hole.
Shari
05-12-2009, 01:20 PM
1967 24' Tradewind
Greenville
, South Carolina
Thanks Shari, although I am interested in buying every specialty tool I out there just because I love tools. The reality is that I can't afford to buy them all! If there is a tool that will do the job resulting in far superior results or much easier I'll try to get it. One of the problems I have had while using my electric drill is that the rivet will start spinning which enlarges the rivet hole. So if a faster drill will end that problem, I may have a case for purchasing a new drill.
05-12-2009, 01:43 PM
Using a cobalt drill bit helps to get through them easily. I used a dewalt battery powered drill on the highest speed setting and it worked okay, but faster is better.
Spinning the rivets won't hurt anything unless you really go crazy with them. I just tilt the drill a little to one side so the drill can cut without spinning the rivet. bucked rivets will expand to fill the hole anyway, so being off a tiny bit won't hurt at all. Not the same for pop rivets though. Try to be as accurate as possible with those ones.
Rich
05-12-2009, 08:44 PM
Los Alamos
, New Mexico
There is a small circle in the middle. It is not there to help you drill them out. It is there for identifying the rivet type. The automatic center punch will make a deeper indent in the top of the rivet.
Michelle TAC MT-0
Sarah, Snowball
05-12-2009, 09:21 PM
1972 25' Tradewind
McHenry County
Absolutly Go Cobalt.
Aluminum, as a drilled metal, gets "gummy" and clogs the drill bits. I’ve used cobalt drills mounted in a regular-plug in hand drill with good lick. The cobalt drills handle the heat build up better and stay sharp longer. Dull bits seem to have more of a tendency to chatter, catch on the rivet and cause the spinning.
Accuracy is more important than getting the perfect curl of metal off the flutes, but it’s a good indicator of the correct speed and pressure of the drill.
Tom.
05-12-2009, 09:44 PM
1960 33' Custom
Athens
, Georgia
my choice
http://www.airforums.com/forums/show...5&postcount=19
I had a similar question and ended up getting the mini air drill as linked. I'm very happy with it and prefer the lower weight and higher speed compared to an electric equivalent.
I used a Hitachi corded drill and a cordless Makita initially before getting the CP.
