Old 05-13-2010, 12:47 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Best approach to repair this damage?
I'm thinking about buying a '58 Flying Cloud. The biggest issue with the trailer is the damaged skin on the streetside wheel area caused by a tire blowout. This is a pretty common problem from blowouts but I haven't seen damage this bad before.
What's the best approach to repair this? A scab over the damaged area? Or replacing a section of the skin. I realize that the best way might not be the cheapest. Just curious what opinions are and what others have done.
Thanks in advance.
Name:	58 Flying Cloud torn wheel well 2.jpg
ID:	102438   Click image for larger version
Name:	1958 Flying Cloud torn wheel well damage.jpg
Name:	1958 Flying Cloud crack.jpg
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 05-13-2010, 01:06 PM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
They usually overlay the skin on the lower side panels to cover damage.
John W. Irwin
WBCCI #9632
Old 05-13-2010, 01:34 PM   #3
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Mike:
For me this would be too big of a rip to patch. I would replace the panel. This panel would not be that hard to replace, as it is a side panel (how long is the panel?) You drill out the rivets to remove the old panel, overlay the ripped panel to the new panel. You then have the full template for the cuts and holes in the new aluminum. Then reverse and install with Olympics rivets (with Vulkem on every Olympic). Two guys could get this done in a few hours of a Saturday.
-Tim
(p.s.: By the way, if the price it right, buy the '59!)
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 05-13-2010, 01:50 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Originally Posted by ts8501 View Post
Mike:
Tim, the trailer body is 19' long (it's 22' overall) so I would imagine that the panel is probably 14-16' long. How much would a sheet of aluminum like that cost?
1958 Overlander
4CU 1st VP
Old 05-13-2010, 02:43 PM   #5
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
So there is no break in that one sheet between the end caps? You might consider cutting off the panel at a rib in front and back of the rip, creating say an 8' panel that you would replace. I can't see exactly the view of your full panel in picture #1. If you did have to buy a full 14'-16', you would want to buy it in a rolled up sheet. It would be buy the foot, and I believe there are 4' wide. I am not near my catelog for a cost, but I believe you need T3-2025 .025".
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 05-13-2010, 05:49 PM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
If it's a 22' trailer the panel is going to be in the neighborhood of 12 to 13 ft. .032 2024-T3 alclad. I replaced mine with .040. Panel replacement is the best option.
Old 05-13-2010, 06:30 PM   #7
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I'd also be thinking about if/when another tire blow-out or tread loss happens - cutting and covering might be good insurance...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Wabbiteer is online now   Reply With Quote
Old 05-13-2010, 08:56 PM   #8
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Good catch! I must have been thinking belly pan. Of course .032!
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 05-13-2010, 09:04 PM   #9
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
I recently measured ny 1955 22' Safari in case I want to replace the streetside lower skin. In my case that panel was exactly 12' long and just over 3' high. I'll probably have to by a 12' x 4' sheet and cut it down. I assume this trailer would be similar.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 05-13-2010, 11:50 PM   #10
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I damaged the entire lower half panel of our '66 Trade Wind. Our insurance paid for the whole thing. All that we paid for was the gas to take the trailer to Toscanos in Los Banos, Ca. The invoice showed that the 14' x 4' 2420 alclad aluminum cost $1200. The job was $3200 and took 12 hours. I located the alumunum source...I'll look it up for you if you need it.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 05-14-2010, 01:31 AM   #11
Neil.
That aluminum price is some what inflated.
Overall the job was about $1200 above the current flat rate manuals.
Old 05-14-2010, 05:48 AM   #12
Images: 59
Right. By about 600%.
Should be able to get a sheet of aluminum for around $200, FOB Aircraft Spruce.
It takes more than a couple of hours on Saturday to do the job though. You'll also need some edge trim for around the wheel well and some repair of the crunched up bellypan.
Old 05-14-2010, 06:12 AM   #13
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
I would agree this job is a little bigger than first envisioned. I did not account for the belly pan or wheel trim work. Having said that, 3 of us replaced a 4x8' (cut to 3x8') sheet from start to finish in less than 4 hours. This included a cut around a window. Since this sheet is 12', and taking into account the belly pan and wheel trim, I'll stop guessing the clock turns.
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 05-14-2010, 06:29 AM   #14
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hi Mike,
If it were my trailer, I'd replace the entire panel. I think that's the best option in maintaining the look of the trailer without it looking like it was patched. My 2 cents.
Good luck with the project, whatever you decide to do.
Chris
Minno is online now   Reply With Quote
Repair Body Damage - Seattle john98103 Ribs, Skins & Rivets 7 06-29-2010 07:56 PM
Damage repair Ron Banks Ribs, Skins & Rivets 7 02-19-2009 05:42 AM
Water damage repair adammoore Argosy Motorhomes 1 05-14-2008 05:53 PM
How do I repair water damage walls? juliesmama Member Introductions 1 09-05-2007 11:10 PM
Body damage repair AccessMaster Airstream Motorhome Forums 0 08-14-2003 11:07 AM
