Old 05-14-2010, 07:10 AM   #15
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Mike, bring it to the restoraton rally next month and a piece of aluminum, and voila you will go home with a new panel. If you don't want to tackle this yourself, I would contact Uwe who you met at our Deadhorse rally.
Hope all is well and cool trailer!
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 05-14-2010, 09:07 AM   #16
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I'm in agreement and would replace the entire panel. Although I have never done it personally, I'll just bet you and I could do this on a long Saturday. Gotta start sometime. I have some clecos but would need another hundred or so and another cleco pliers.
Do all of you experts think that Olympics would be strong enough and seal well enough for an entire panel replacement?
Got any shade up at your house?
FF
On edit: I see Louis has a great idea about the resto rally. Don't let this one panel keep you from getting this trailer. It'll get fixed one way or another.
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 05-14-2010, 09:16 AM   #17
FF
Olympic rivets, when properly used, will hold the metal to the shell without any problems. They have already been in use some 40 years without problems.
Aircraft Spruce does not stock any alclad aluminum larger than 4' X 12'. Very few places carry alclad in larger sizes.
You may have to use a sheet of the newer material, that's available from Airstream, and cut it down to the size you need. But, it's only available in certain lengths.
Old 05-14-2010, 10:20 AM   #18
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
The Resto Rally is a great option. Where do you think I learned how? I no longer fear the Aluminum! The aluminum does not yet fear me, but we are getting there. Wish I could attend this years rally. I highly recommend it for all restorers, and what a great place to replace a panel. Everyone pitches in to help and learn.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 05-14-2010, 10:57 AM   #19
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
We did exactly that panel on Area 63's 1958 Flying Cloud last year, at the restoration Rally. And the other side, too....
It was done as part of metalwork hands on demonstrations.
The panel is 12ft long, and 39in high. We used 2024 Alclad, from Airparts inc in Kansas. They have 4ft alclad on a huge roll, and will cut any length for you.
The front street side window will have to come out, which is a perfect time to clean it up and overhaul it.
While I personally prefer original style bucked rivets, Olympics will work fine if you do not want to remove the interior skin.
Uwe
www.area63productions.com
Old 05-14-2010, 11:34 AM   #20
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Wow, thanks, everyone, for the numerous responses. I agree that the best way would be to replace the entire lower side panel.
BTW, I looked at this trailer last night and it's pretty rough. The floor will need replaced and the curbside upper curved front panels have a dent that is worse than the pics depicted. The inner zolotone panels, though, look great and have not been painted over.
UWE, does your Flying Cloud have a black tank? This one didn't. It just had a sewer hookup underneath the toilet. Does the gray water drain out
this hole, too?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 05-14-2010, 12:32 PM   #21
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Custom 2024-T3 ALCLAD is available - .032 48" width any length $15.75 per foot...
2024 T3 Alclad Aluminum Coil and sheet, rolled aircraft aluminum
(Note: their website likes Internet Explorer, loads blank page with FireFox)
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 05-14-2010, 12:45 PM   #22
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Wow, that's all? This repair won't be as bad as I thought. Thanks Wabbit.
1958 Overlander
4CU 1st VP
Repair Body Damage - Seattle john98103 Ribs, Skins & Rivets 7 06-29-2010 07:56 PM
Damage repair Ron Banks Ribs, Skins & Rivets 7 02-19-2009 05:42 AM
Water damage repair adammoore Argosy Motorhomes 1 05-14-2008 05:53 PM
How do I repair water damage walls? juliesmama Member Introductions 1 09-05-2007 11:10 PM
Body damage repair AccessMaster Airstream Motorhome Forums 0 08-14-2003 11:07 AM
