Old 09-11-2010, 10:42 AM   #1
1968 20' Globetrotter
Kelowna , British Columbia
Bent rib
My next challenge is to repair the damage to the street side of my GT incurred by the PO. I noticed the long dent in the street side matched the contour of the 'designer' rock in his driveway!
I will replace the outer skin...aluminum is on its way from Aircraft Spruce...but the main front rib/bow is bent, as is the second from the front.
The second....lighter ...rib doesn't look too hard to repair, but the main front bow is tough. Hers is a photo with my shade-tree porta-power in place.
I got some movement with this method but the c clamps holding the chain started to bend. I'm thinking of drilling the rib...nothing to lose...and using shackles to hold the chain. Would heating help? Would this annealing significantly weaken the rib? Does anyone have a 2 or 3 foot piece of rib I could splice in?
Ian
Canlib is offline   Reply With Quote
Old 09-11-2010, 11:10 AM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
I think you're on the right track; you might consider either beefier C clamps or clamping metal blocks in place behind the rib edge and fastening the chain to those. Note that if you can replace most of the chain w/ a metal bar (scrap steel square tubing works well here, the loads on the anchor points go down a lot.
I'd avoid heating the rib if possible; the loss of strength is dramatic and not that great an idea in a structural member like a rib.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 09-11-2010, 11:40 AM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Remove the skin rivets from the frame and it will straighten much easier.
Oops, it looks like you already have
Old 09-11-2010, 11:50 AM   #4
Attachment 110537
Ian
Ian.
Cut the rib, like a small "V" cut, on the side that is damaged the most, then position it correctly.
Then add a thick plate on the side of the rib and fasten it with several 3/16 pop rivets.
For the final touch, you can add small pieces of thin aluminum to the outside of the main bow, as "shims".
This can be done in just a few minutes, instead of trying something elaborate, that as your finding out, corrects one part, but damages another part.
Old 09-11-2010, 08:35 PM   #5
Thanks Andy... you saved me from myself!
Ian
Old 09-11-2010, 08:40 PM   #6
Ian
Easy does it for yourself, Ian.
Bandages are cheap.
Asking questions is the easy part.
Digesting the answers, separating opinions, sometimes is a problem within itself.
Just wait and see what questions you come up with as your project progresses.
Many of us here are glad to help.
Old 10-24-2010, 04:57 PM   #7
Repair Follow-up
I used Andy's method to repair the bent ribs. I cut wood templates from the corresponding ribs on the other side, cut the rib at the bend, clamped on the template and riveted on the reinforcing patch. EASY!
Thanks again Andy!
Ian
Name:	bent rib  013.jpg
ID:	113932 Click image for larger version
Old 10-24-2010, 05:22 PM   #8
x
XXXX , XXXX
Hey Canlib is that your TV in the background. LOL
wasagachris is offline   Reply With Quote
Old 10-24-2010, 05:25 PM   #9
Yeah Chris....needs a little work!
Old 10-24-2010, 05:31 PM   #10
x
XXXX , XXXX
At least you don`t need Air con in the TV. Youve got the model 260 air. 2 windows and go 60 MPH.
Do you intend to restore it as well.
What yr and model is it anyway.
Old 10-24-2010, 05:46 PM   #11
That one is way down the to-do list. Its a 1952 Willys pickup that I only have the body for. The complete 1951 Willys is higher up the list, but once the GT is done and we are on the road....what list?
What are the Stud/Rib centers? dailyphoto Cabinets, Counter Tops & Furnishings 4 07-30-2010 02:16 PM
rib failure - ouch. mbattin Ribs, Skins & Rivets 15 06-28-2010 03:15 PM
rib insulation vet57air General Interior Topics 3 08-22-2009 02:56 AM
Damaged Rib repair rpark01 Repairing/Replacing Floor &/or Frame 8 05-19-2009 02:34 PM
bent/cracked rib? Jabba Ribs, Skins & Rivets 1 10-27-2002 06:04 AM
