Old 08-26-2011, 01:22 PM   #1
Tino
Tino643's Avatar
2013 27' FB International
Blainville , Quebec
Beltline
Hello first post. sorry for the english. I am from Canada the french part (Québec). I have a new airstream and the belt line and rub rail trim is pulled away in one place on my door. I wonder if i should I put any sealent behind the trim before and behind the rivet before I rivet the loose area? Also what length rivet do I use? Thank you...
Tino643 is offline   Reply With Quote
Old 08-26-2011, 03:30 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I would return a new AS to the dealer for a warranty repair. If it is something you want to repair on yor own, yes you need to seal the back of the rail. Trempro 635 is what I like, and is used by several here.
Available from several sources, like Vintage Trailer Supply, at this link:
TremPro 635
May also be found at some local fasterner and high end hardware stores.
A "medium" reach rivet should be fine.
Regards,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-27-2011, 07:11 AM   #3
Tino
Tino643's Avatar
Blainville , Quebec
Tanks for the link. And i can't take the trailer back to the dealer because i bougnt it in USA and it is to long to go back there just for this litle thing. So i will repair it my self.....
Old 09-04-2011, 02:18 PM   #4
Ottawa , ON
Be certain to use aluminum rivets on that door. Steel ones will corrode.
Rear storage leak - 2004 Classic? art 2001 - 2005 Classic 47 01-31-2012 07:03 PM
Dent removal along beltline jonny Ribs, Skins & Rivets 7 07-22-2011 09:21 AM
What to rivet, and where to rivet it? DanielB Ribs, Skins & Rivets 5 04-27-2011 09:06 PM
How tough to take off the banana wraps? johnhh Belly Pans & Banana Wraps 11 04-27-2011 10:22 AM
