Old 10-27-2010, 12:35 PM   #1
urban71's Avatar
2010 19' International
San Francisco , California
Images: 11
Belt Line Trim Removal Advice
I am looking at removing the beltline trim on a 71 Overlander. The trim is pulling away from the skin and looks pretty bad. I would like to simplify the exterior look a little as well.
Has anyone done the same who could post some images of the results and offer a little advice? I assume I need to go back after the trim is off with Olympic rivets to seal up the skin.
Thanks in advance!
laugh.listen.respond.
urban71 is offline   Reply With Quote
Old 10-27-2010, 12:51 PM   #2
Thanks in advance!
When you remove the belt line, I think you will find that the side sheet has been somewhat damaged and or discolored by the belt line moldings.
That molding would only pull away if the trailer has been subjected to severe vibration, such as caused by a super heavy duty tow vehicle, and/or excessive rated hitch bars, and/or a bad axle/axles, or a combination of those.
That molding "does not" fail by itself.
Old 10-27-2010, 04:07 PM   #3
urban71's Avatar
Images: 11
Thank you Andy - the failure has happened at a few spots, not all the way around the unit. Does it provide seam support / protection? I don't want to open a can here by removing it. I saw in a previous post that in 71 AS utilized a tape on the beltline. Is that still available?
Old 10-27-2010, 04:21 PM   #4
The top belt line molding covers some of the lower sheet/window sheet seam.
It's strickly decorative.
It's better to paint the blue stripe instead of tape. The tape has a short life.
The tape has not been available for at least 35 years, but it should be available locally. Everyone will tell you don't, but it's your choice.
Anyd
I need a piece of belt-line trim... malconium Clearcoat, Exterior Paint & Trim 14 09-28-2017 11:01 AM
Addressing Belt Line Corrosion moosetags Ribs, Skins & Rivets 1 08-23-2009 05:23 PM
belt trim attachment equigley Clearcoat, Exterior Paint & Trim 3 10-25-2007 08:42 PM
Belt Line Trim Needed For 1956 F.C Dan Clayton Clearcoat, Exterior Paint & Trim 2 08-04-2006 09:47 PM
ID'ing a Model by the Belt Line styling jaco Airstream Trailer Forums 5 02-25-2004 01:06 PM
