Old 10-25-2015, 06:42 PM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Originally Posted by nrgtrakr View Post
I use a slightly larger bit, stop the drill when rivet head spins, push or punch out the remains.
I concur.
Brevi tempore!
Old 10-25-2015, 06:44 PM   #16
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Originally Posted by malett View Post
a sharp wood chisel with the bevel up so it will not dig in works excellent. may have to sharpen often, but is quicker and much less effort. no spinning rivets, no chips and leaves cleaner holes once the old rivet is punched out. masking tape cam be used if you are concerned about leaving marks. theoretical you are shearing the rivet and not cutting it.
This works great also, it is the fastest way and very effective.
Brevi tempore!
Old 10-26-2015, 11:49 AM   #17
1981 31' Excella II
New Market , Alabama
I have used the chisel before and it works till you hit one with a steel core. I would not use it on the shell skin but I have used it on the belly and interior rivets. Not sure how good it would be with solid rivets.
Perry
Old 10-27-2015, 05:38 PM   #18
1976 31' Sovereign
Pittsburgh , Pennsylvania
Originally Posted by Mixter View Post
Picked one up yesterday, what a game changer!
Thanks!
gronlampa is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
#20 drill bits bimpy Ribs, Skins & Rivets 30 03-29-2012 03:22 PM
Drill bits and Rivets jasmith58 Exterior Restoration Forum 8 01-28-2010 03:26 PM
