Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Prev Previous Post   Next Post Next
Old 09-01-2009, 09:20 PM   #1
Gregg S's Avatar
Profile:  2002 25' Safari
2009 16' DWR
quincy , Massachusetts
Belly Pan Rivet question
I just noticed that I have a few broken rivets in my 02 Safari belly pan with a few of the rivets holding the clamps for a water line. A couple of the heads have ripped through the pan.
So the questions are:
How should I repair the area around the damaged alum pan?
What is the size and lenght of the rivets needed to replace the old ones?
Can I drill out the rivets and use sheet metal screws?
Gregg S is offline   Reply With Quote
what size rivet for U channel, skin and belly pan connection? benWa Ribs, Skins & Rivets 5 09-22-2009 09:49 PM
Belly pan off or on ? augier Belly Pans & Banana Wraps 6 08-08-2009 03:04 PM
belly pan hlink Belly Pans & Banana Wraps 10 09-16-2008 08:51 AM
Can you help? Water in belly pan question Eddy General Repair Forum 5 07-04-2007 07:10 PM
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 16 07-18-2004 09:16 PM
