Old 11-28-2013, 01:25 PM   #1
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
Bead roller advice needed.
this might have been answered here before, but i am looking for a bead roller, to replicate the corners of some of the exterior sheet metal.. especially the conrner around the old style entry door (the one with door in door).
has anybody done this here and have some advice as to what type of bead roller to use or where to find one?
im also having to rebuild some of the window rain gutters.. any advice?
thanks
submariner is offline   Reply With Quote
Old 11-28-2013, 01:41 PM   #2
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
You might want to PM aerowood. He does aircraft repairs for a living. He seems to know his stuff.
In stead of making new pieces, you can buy many body panels from Inland RV or Outdoors Mart. Also try Vintage trailer supply.
Silverflames is offline   Reply With Quote
Old 11-28-2013, 02:00 PM   #3
submariner's Avatar
1948 22' Liner
1989 34' Limited
well. buying replacement panels is out of the questions, as i am working on a 48 Liner.
i did noticed , that the corner at the door is broke and not rolled, however the lower corners for the roof section are rolled.
I do like to have the tools for the job on hand though.. therefore looking for the right (inexpensive)source
Old 11-28-2013, 02:18 PM   #4
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
In this link aerowood describes a homemade one using bearings. This is what I used. Made my own and a little practice http://www.airforums.com/forums/f381...tml#post321300
FC7039 is offline   Reply With Quote
Old 11-28-2013, 03:01 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Aircraft Spruce Sells this edge bending tool that does a good job.
EDGE ROLLING TOOL from Aircraft Spruce Canada
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 11-28-2013, 04:30 PM   #6
submariner's Avatar
1948 22' Liner
1989 34' Limited
thank you guys.. this info helps a lot. i probably will purchase a bead roller similar to the harbor freight tool.
Old 11-28-2013, 04:31 PM   #7
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
A while back I replaced many panels on a 57 Overlander. I ended up having a sheet metal fabricator do the edge/ bead detail for me. I would cut out my new panel take it in to them and have the bead work done and pick them up a few days later. Instead of spending money on tools and then practicing for hours I chose to have someone do it for me
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 11-28-2013, 07:20 PM   #8
Baltimore , Maryland
Ö however the aluminum the panel is pressed out of is totally different aluminum and your panels will never match the rest.
Old 11-29-2013, 07:29 AM   #9
submariner's Avatar
1948 22' Liner
1989 34' Limited
i plan on purchasing 2024t3 aluminum from aircraft spruce, and also found the same bead roller, that harbor freight sells on eaby for much less with free shipping..
I just prefer to have the tool myself, instead of having to go somewhere and have them do it..that way i can work at my own pace though.. and i can use it in the future as well..
thanks
Old 11-29-2013, 07:59 AM   #10
1969 29' Ambassador
I think what 62overlander is referring to is the new panels you can buy for a AS. I guess the are a different grade metal and will not match or polish correctly. So they would stand out..
I have been paying labor on all of my brake work, and for what I have spent in labor, i could have bought a brake and sheer from HF.
Old 11-29-2013, 10:39 AM   #11
FC7039's Avatar
Allen , Texas
I actually bought a bead roller from HF only to return it. This may be due to my ignorance of its use but I found the dies were too big for the edge shapes you are after and that it is a two person job to move the panels through the press and crank it. I did not give it a lot of effort before I determined it would not do the job. But you may. Your 48 would have flat panels that can be made from sheet alum. No need to buy from anyone if they are even for sale
Old 12-01-2013, 06:25 AM   #12
submariner's Avatar
1948 22' Liner
1989 34' Limited
i was looking at the HF bead roller yesterday and noticed, i can get the same one with free shipping from fleabay... I do have a lathe and therefore be able to turn a die if needed.
Yes the 48 has straight panels, but also all roof panels have a rolled lower edge.
thanks for the help so far. i will continue the actual restoration in the 48 Liner thread
Old 12-01-2013, 07:04 AM   #13
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Originally Posted by submariner View Post
i was looking at the HF bead roller yesterday and noticed, i can get the same one with free shipping from fleabay... I do have a lathe and therefore be able to turn a die if needed. Yes the 48 has straight panels, but also all roof panels have a rolled lower edge. thanks for the help so far. i will continue the actual restoration in the 48 Liner thread
Your workmanship is so good (saw your mail box) you should have a quality combination beader & crimper. You maybe able to find one close to an industrial area where a sheet metal shop or insulation contractor is selling off old equipment or a flea market or industrial auction. Failing that, Shacksman knows what he is talking about so his recommendation would definitely work and the price cannot be beat. Jim
Jim Flower is offline   Reply With Quote
Old 12-02-2013, 08:05 PM   #14
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
Look at those available on Eastwood's web-site. The have several and they have interchangeable dies. I see that they advertise on this web-site as well.
Dennis
1997 25' Safari
2012 Chevy Silverado HD 2500
Duramax/Allison
dirigible25 is offline   Reply With Quote
Advice Needed on Old Airstream cboling Our Community 9 01-18-2012 01:26 PM
Motorhome floor repair advice needed. Keyair Repairing/Replacing Floor &/or Frame 0 10-06-2011 10:44 AM
Shattered window in '98 Airstream- advice needed NoMoSOBs Windows & Screens 18 07-29-2011 01:14 PM
Considering a '67 Overlander, Advice Needed hlo Buyer Guidelines 3 06-16-2011 01:56 PM
Looked at airstreams today.. Advice needed. mikeandnora Buyer Guidelines 45 02-09-2011 11:27 PM
