Old 06-05-2009, 05:58 PM   #1
mtjim's Avatar
1973 25' Tradewind
New Bloomfield , Missouri
Basketball Dent - What do you think?
Airstream got a basketball dent in the driveway. Grandkids - can't live with them and can't live without them!
What do you think?
Repairable by amateur? How would you go about it?
Other suggestions?
mtjim is offline   Reply With Quote
Old 06-05-2009, 07:29 PM   #2
1976 25' Caravanner
Campton , New Hampshire
It might be repairable , hard to tell without trying . It won't be perfect , depends on what is acceptable to you.
First stage , try your local body shop and see if their suction puller will pull it out
Second stage , remove the interior plastic end cap and massage it out from the inside.
Stage three , have the panel replaced , about a grand.
Check with your insurance.
Good luck
ticki2 is offline   Reply With Quote
Old 06-05-2009, 07:36 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Yeah I would try the suction puller first. Make sure the aluminum is good and hot. I will work better than if it is cold.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-05-2009, 07:56 PM   #4
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
My brother pulled out a much deeper dent than this one using a Product called Dent King from an auto parts store. Get it warm out in the direct sun and give it a shot.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 06-05-2009, 10:31 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Suction cup or story?
Hi, I would try the suction cup method first and if that doesn't work then it could be a good campground story. "Yah, me and the grandkids were playing basket ball and........................................"
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-05-2009, 11:56 PM   #6
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
That dent was created by a basketball traveling at warp speed! Were the g-kids having a slam dunk contest?
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-06-2009, 07:31 AM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
That's Ding King. The same product is available under the name Pops a Dent. It should reduce the dent quite a bit. You can do the same thing with some short 2x2 lumber, a hot glue gun and a hair dryer.
Lumatic is online now   Reply With Quote
Old 06-06-2009, 09:29 AM   #8
2008 25' Safari
Jasper , Georgia
Don't delay if you are going to use a dent puller. The sooner you pop the dent,
the more likely it will return to normal. Wait and the dent is a lot harder to pull out and get it looking normal again.
Paul&Dee is offline   Reply With Quote
Old 03-12-2010, 10:33 PM   #9
Bo&Susan's Avatar
Daleville , Alabama
Any pictures of how this works. Thanks Susan
Bo&Susan is offline   Reply With Quote
Old 03-12-2010, 10:50 PM   #10
Yhottys's Avatar
1960 24' Tradewind
1961 16' Bambi
Oakland , California
Huge Suction Cup
We had a dent about the same size but deeper almost right in the middle of the back of our 1974 Tradewind.
We popped it out with a huge suction cup with a little lever that you flip once you create a seal-less than ten dollars. No hot glue necessary. We did it on a 90 degree day and it litterally popped right out.
You can see the dent in the image below or click on our "Images" for a larger image. It was taken one day after we purchased our trailer.
Good luck and please let us know how things turn out!
Gemma and Murray
Yhottys is offline   Reply With Quote
Old 03-12-2010, 11:01 PM   #11
Salem , Oregon
Images: 18
Hi, my friend DG at work, at the Jackson Rancheria Rally. Not perfect, but a lot better.
Name:	IMG_0952 (Large).JPG
ID:	98005   Click image for larger version
Name:	IMG_0956 (Large).JPG
Name:	IMG_0957 (Large).JPG
ID:	98007   Click image for larger version
Name:	IMG_0958 (Large).JPG
2005 Safari 25-B
Old 03-16-2010, 07:18 AM   #12
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
...can you provide any addl info on DG's expertise, Bob? I tried a Harbor Freight cheapo puller, no luck, went the Ding King - hotgluegun route, no luck... any insight is appreciated..
fotochop is offline   Reply With Quote
Old 03-16-2010, 11:48 AM   #13
funkill's Avatar
reno , NV
Images: 27
I contacted a local *paintless dent removal* company who did a good job of pulling out my dent (of similar size and location, though mine was at a seam) for a really reasonable price. See my post for pictures: http://www.airforums.com/forums/f381...hit-59265.html post #11 for before, post #30 for after pics
Laura
funkill is offline   Reply With Quote
Old 03-16-2010, 11:50 AM   #14
funkill's Avatar
reno , NV
Images: 27
Watched a guy in a campground trying this technique of pulling out the dent himself, using a double handled suction device. But he was standing on a ladder. Yikes. First good pull and he about yanked himself off the ladder.
Laura
Got dent! pjude Exterior Restoration Forum 7 11-28-2008 09:46 PM
Dent flyguy Ribs, Skins & Rivets 19 06-08-2007 12:46 PM
First Dent - HELP! JimGolden Ribs, Skins & Rivets 10 01-08-2007 12:47 PM
Dent Removal Steve Heywood Ribs, Skins & Rivets 21 06-18-2005 07:51 PM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 11:43 AM
