Old 03-16-2010, 01:05 PM   #15
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
I can't stand this guy, but even though he is dead, his voice lives on. Here is a Utube video showing how the DingKing works:
hhendrix is offline   Reply With Quote
Old 03-16-2010, 02:08 PM   #16
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
You Rang
Originally Posted by fotochop View Post
...can you provide any addl info on DG's expertise, Bob? I tried a Harbor Freight cheapo puller, no luck, went the Ding King - hotgluegun route, no luck... any insight is appreciated..
I have about 6 different size suction cups. some with handles some used to hang stuff on the fridge.
Funny the ones in the pic that Bob provided are harbor freight cheapies. I've had good success with them.
problem with aluminum is that once it stretches it kinda stays that way.So therefore it's easier to get a better finished product with a shallow dent on a flat surface, compound curves are another thing.Anytime there are 2 sheets riveted together it becomes more difficult to smooth things out. I'm thinking that the next time I run into an overlap I'll drill out the rivets and see if that will allow the panel to move a little.Then rerivet. My aircraft experience has shown me that a very small size will make a difference.( usually when fabricating - join up the panels with #40 bit and cleco- then go back and drill#30,). And I would have no problem drilling a few new holes. but that's me.There are a lot of good sealers out there to close up any space between surfaces. It's always best to remove the inner panel also. Gives you a lot more options. I've used basketballs, softballs. dowels, beer bottles, well you name it, on the inside surfaces with very good results.
It's already messed up, how much more damage can one do to it??
If you're the kind of person that could get both hands caught in a vise do not attempt any of the above. seek help
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 03-16-2010, 02:53 PM   #17
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Originally Posted by funkill View Post
Watched a guy in a campground trying this technique of pulling out the dent himself, using a double handled suction device. But he was standing on a ladder. Yikes. First good pull and he about yanked himself off the ladder.
Laura
Did you find someone to replace the rivets on your roof repair? or at least the right answer to making seam waterproof.
Got dent! pjude Exterior Restoration Forum 7 11-28-2008 09:46 PM
Dent flyguy Ribs, Skins & Rivets 19 06-08-2007 12:46 PM
First Dent - HELP! JimGolden Ribs, Skins & Rivets 10 01-08-2007 12:47 PM
Dent Removal Steve Heywood Ribs, Skins & Rivets 21 06-18-2005 07:51 PM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 11:43 AM
