Old 04-10-2009, 08:01 PM   #1
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Bambi hinge rivets?
Anyone know what kind of rivets these are on the Bambi (1961) door hinges? They are big and conical, they almost look like they are some kind of pop rivets that have been shaved (see the little dot in the center--these do not look like the dots you sometimes see in the center of solid flush rivet, it looks more like a little hole that is almost closed the shaving action).
I think this info has been posted previously, but can't find the post.
Name:	IMG_0725 door rivets-s.jpg
ID:	78194 Click image for larger version
Name:	IMG_0727 door rivets-s.jpg
Zep
Old 04-10-2009, 09:30 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Zep ~
Where did you get these photos? Is there a chance these are bucked rivets that were installed either at the factory or by an owner? They look very solid to me. I sure could have used those to keep my door from coming off.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 04-10-2009, 10:01 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Those look like 5/32 brazier head in 2117 aluminum or an AD. to get the same dead diameter in a 470 one would have to use 3/16 rivets.
Old 04-10-2009, 10:33 PM   #4
1975 31' Sovereign
1977 23' Safari
They are definitely too peaked to be brazier heads. Think Madonna's bra. And the head diameter is bigger than 1/8" brazier or 5/32" modified brazier. Is it possible they are standard 5/32" brazier heads (which would be bigger than a modified brazier head)?
It's the strange peaked/conical shape of the head that has me buffaloed.
Zep
Old 04-10-2009, 10:37 PM   #5
Aerowood's Avatar
Arvada , Colorado
yep
Old 04-12-2009, 08:05 PM   #6
1975 31' Sovereign
1977 23' Safari
Turns out they are 5/32" solid rivets with Madonna bra cup heads.
The dot in the center is just a drill centering dimple. Easy as pie to drill out.
Zep
Old 08-29-2009, 12:35 PM   #7
Vintage Trailer Supply
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
I believe the dot in the head means it is a hard rivet, which would make sense on a door hinge. Universal rivets are more domed than braziers. Could that be it?
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Damaged Rivets on Window Hinge Tom Bray Windows & Screens 8 02-05-2011 11:14 AM
Popping Rivets Inside my '07 Bambi iHayley Ribs, Skins & Rivets 9 10-06-2008 06:43 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 01:35 PM
Rivets in 2006 Bambi pagoff General Interior Topics 6 08-08-2006 12:39 PM
