Old 06-08-2011, 07:02 AM   #1
MichiganSilver
1978 25' Tradewind
Saline , Michigan
Back skin normal?
Looking at this 25 tradewind tomorrow. It looks like the skin looks a little bubbled on the back side at the rivets around the wheel wells. I've read about separation issues. Want to make sure I am not missing something, as this would be my first Airstream. This trailer looks well cared for and was told the back floor was solid.
akacheryl is offline   Reply With Quote
Old 06-08-2011, 07:09 AM   #2
MichiganSilver
1978 25' Tradewind
Saline , Michigan
Should have mentioned it's a 1978!
Old 06-08-2011, 07:33 AM   #3
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
Do you have any pictures ?
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 06-08-2011, 07:34 AM   #4
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
akacheryl
It's just so much easier if you post as many pictures of the trailer as possible
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 06-08-2011, 09:31 AM   #5
funkill's Avatar
reno , NV
Images: 27
Yeah, that's what I thought too. I had two other guys look at my rear end for the separation issue and even they didn't discern the wood rot. I found it after 2 years of poking around and even removing the bathroom carpeting. I didn't notice until I did some really close inspection of the area in the rear compartment/storage area. I presume my damage is due to the typical rear bumper hatch cover/trim leak. Mine is not showing rear separation yet - but with the wood damage, I expect it is forthcoming. So, while the floor might be solid on the interior, the edges where it secures into the C-channel might not be....
Do your own inspection and don't rely on only what the owners say. Not that they are trying to deceive you - but maybe they aren't as *informed* as others. The Previous Owner (PO) of my trailer said it didn't leak - which is pretty unlikely with any year trailer. I didn't notice leaks until the time that I didn't have it level (i.e. too low in the front and too lazy to fix) and the rain water ran in. Next time it was level and it was much less obvious. The PO didn't know about axles wearing out, rear end sep, gaskets rotting or ..... Well, you get the idea!
Happy hunting and I hope that trailer IS solid!
Laura
funkill is offline   Reply With Quote
Old 06-08-2011, 10:03 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Stand a bit ahead & behind of both front & rear corners of the Tradewind. Viewing at a shallow glancing angle, concentrate on the side skin just above & behind each wheel well. Does it look like it stays flat through this area? Is there any slight change of light reflection suggesting the skin has developed a slight bulge or hollow just aft of either wheel well?
Such a change could be indicative that the frame has sagged due to separation of connection at the lower rear of the shell.
Pictures sure would help once you get to see the coach -- taken at the same glancing angle.
5 meter Langford Nahanni
Old 06-08-2011, 10:16 AM   #7
MichiganSilver
1978 25' Tradewind
Saline , Michigan
78 tradewind
Thought I had attached one. This is the only picture I have of this side
ID:	132016   Click image for larger version
Old 06-08-2011, 10:17 AM   #8
MichiganSilver
1978 25' Tradewind
Saline , Michigan
The street side is showing stress on the rivets
Old 06-08-2011, 11:30 AM   #9
MichiganSilver
1978 25' Tradewind
Saline , Michigan
This may help explain a few things. The current owner just explained that previous to his buying, the trailer caught a camp site marker on the street side. The insurance company scrapped the trailer, but the trailer was later repaired and sold with a salvaged title.
'83 sofa back piece folds out yonallycamp Upholstery, Blinds, Walls & Interior Finishes 1 04-30-2011 02:59 PM
Should I add wheels to the back bumper? Scott J-24 Towing, Tow Vehicles & Hitches 12 04-04-2011 06:40 PM
sticky black tape between interior skin & frame? clipperguy Ribs, Skins & Rivets 1 03-21-2011 04:00 AM
Placement of lower curtain tracks over back gaucho 73 Tradewind. constructor Upholstery, Blinds, Walls & Interior Finishes 1 03-17-2011 06:22 AM
How do you cover the back of your truck? aname4me Tow Vehicles 34 03-01-2011 12:36 AM
