Old 01-20-2013, 02:05 PM   #1
1979 23' Safari
Las Cruces , New Mexico
Arrow Aluminum rivets at Lowes
Are these pop rivets Aluminum shank and adequate for interior, belly pan etc uses where Buck Rivets aren't required?
Greg
apltrez is offline   Reply With Quote
Old 01-20-2013, 02:17 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
They say they are aluminum but I'm pretty sure they have a steel mandrel.
reinergirl is offline   Reply With Quote
Old 01-20-2013, 02:18 PM   #3
1986 31' Sovereign
Miami , Florida
All good but you might want to get some of the large headed rivets from Vintage Trailer Supply for the belly pan. Work a lot better with that thin sheet stock.
Mike
Old 01-20-2013, 02:19 PM   #4
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Greg
yes, they work as intended. I used many of those rivets. For sharper look, I have used Olympic blind rivets on the inside as well.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 01-20-2013, 04:08 PM   #5
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Greg
It will say on the package what kind of mandrel. I have seen both kinds in the big box stores. Avoid steel mandrels--they rust and are terrible to remove (not because of the rust, because it's really hard to drill into the center of the rivet).
If you find some holes that have been damaged and are too big to hold a 1/8" rivet securely, use a 3/32" in its place.
You need 3/16" rivets for the belly pan. Even better, get the big head versions from Vintage Trailer Supply.
Z
