Originally Posted by deepsea27
Here is a pic of the rivets I'm looking for. I have the larger rivets now I need the smaller ones.
The very small rivets are used to attach the window hinge, and to rivet the window sash (metal around the glass) to the steel bar that's within the sash, that holds the 2 pieces of sash together.
They are available from Aircraft Spruce. The spec number is AN 470 AD and the size is 1/4 inch shank X 1/8 inch diameter.
But, they only sell them in 1/8 or 1/4 pound packages.
Also, they are green in color (alodine). That can easily be removed by soaking them in "Limeaway" for a few days.
Airstream does not sell that small rivet, unfortunately.
They are very cheap, but even the small package of them will contain several hundred.
