Old 04-22-2010, 04:46 PM   #1
1960 24' Tradewind
anyone in Austin, TX have any 1024-T3 ALCLAD?
I need just one little piece, 44 X 30 inches. Any suggestion on where to get one that size?
My '60 tradewind has battery acid corrosion on the front.
PetervB is offline   Reply With Quote
Old 04-22-2010, 05:00 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Do you mean 2024-T3?
You can order as much or as little as you need from Airparts or Aircraft Spruce...it's usually 48" x ???? when purchased from a coil. A piece that small wouldn't cost much...a 48"x48" piece of .032 is only about $50
Shari
Old 04-22-2010, 05:41 PM   #3
Airstream Rescue
rptradewind's Avatar
1948 22' Liner
1966 20' Globetrotter
Wimberley , Texas
If you don't mind a drive, Westbrook Metals in San Antonio sells 2024-T3, .032" by the square foot in 48 Inch widths. They have a slight cutting charge. You can also try Westbrook metals in Austin but the last time I was there they didn't carry it.
Good Luck
Pat
rptradewind is offline   Reply With Quote
Old 05-28-2010, 05:40 PM   #4
1960 24' Tradewind
Westbrook metals for aluminum supply
I picked up one sheet of 2024-T3AL at westbrook metals in San Antonio. Price was $220 for a 4x12 sheet.
Airparts and Aircraft Spruce are nominally cheaper but after shipping this was a lot less!
I'll have some left over after my project is complete and then I'll sell it.
Airstream Karma -- Out with the Vinyl, In with the Alclad riggsco Upholstery, Blinds, Walls & Interior Finishes 15 09-12-2010 09:00 AM
2024-T3 alclad aluminum toastie Ribs, Skins & Rivets 6 03-31-2010 07:44 AM
Alclad? realpank Classic Motorhomes 28 02-08-2007 12:54 PM
Help!! Austin-to-LA-to-Austin Astro On The Road... 13 04-05-2006 10:29 PM
Getting an AS from Austin, TX to NM abruzzi Towing, Tow Vehicles & Hitches 11 07-19-2005 08:42 PM
