Old 08-11-2008, 07:46 PM   #1
jkrauk's Avatar
1978 23' Safari
1956 22' Flying Cloud
Orlando , Florida
Aluminum size
I am working on the exterior of my new 1978 Safari. It has a big bash in the street side that I am going to replace with a new sheet. What do I ask for at my local supplier of metal? Will it look right when everything is polished up?
Thanks.
jkrauk is offline   Reply With Quote
Old 08-11-2008, 07:49 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Thanks.
2024 T-something Alclad aluminum. If the piece is perfect;y straight, then a thickness of .040 will give you a nice straight appearance. Stock is .032
for teh exterior.
It will shine up and look pretty similar to the other metal, or at least close enough. The end cap segments sometimes have a different sheen to them, but usually not the straight parts.
Uwe
www.area63productions.com
Old 08-11-2008, 08:35 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
like Uwe said, 2024-T3 alclad .040
Old 08-11-2008, 10:51 PM   #4
Thanks.
The length of your side sheets are 13 feet.
The lower panel height is 32 inches and the window panel is 56 1/2 inches.
The original thickness of both those panels was .032, but you can use .040.
Finding alclad with those dimensions is near impossible.
However if your going to polish the trailer, you can use the material that Airstream currently uses.
Again, use caution regarding the dimensions.
Also be sure you use plenty of Vulkem sealer in the right places.
What size mok Member Introductions 4 05-31-2008 05:50 PM
what size a/c? RichardT Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-15-2008 08:30 PM
Twin Size Size Over59 Upholstery, Blinds, Walls & Interior Finishes 5 08-20-2004 10:18 AM
What size do I need? Tin Hut Batteries, Univolts, Converters & Inverters 3 04-07-2004 06:30 AM
What size aluminum for under belly? Bryanhu Belly Pans & Banana Wraps 6 08-22-2003 06:10 PM
