07-26-2006, 11:29 AM
a.k.a. Ambassador Tim
1960 28' Ambassador
Northern
Aluminum siding needed
I have removed the water heater, oven, and furnace from the Ambassador.
I'm not planning on putting anything in those openings so I need to cover them up.
If anyone has any extra aluminum that they have left over and want to sell it I need the following:
6" x 6"
6" x 20"
21" x 23"
21" x 24"
If no one has any available, where's the best place to purchase?
Thanks.
07-26-2006, 12:29 PM
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise
Aircraftspruce.com will sell the 2024-T3 in small sizes. They send it UPS rolled up in a box.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
07-26-2006, 12:42 PM
1972 27' Overlander
Longmont
Hd
hi- I found sheets of aluminum, up to 24" by 24" readily available at HD, and Ace hardware. You also might find it at your local plumbing-hvac shop.
07-26-2006, 01:38 PM
1960 28' Ambassador
Northern
What thickness should I look for?
07-26-2006, 05:55 PM
Corona
2024 T 3 aluminum.
.032 inches thick.
07-26-2006, 06:02 PM
1960 28' Ambassador
Northern
Great. Thanks everyone.
While I have your attention. What should be used for the belly pan?
07-26-2006, 06:17 PM
Corona
Use the same 2024 T 3, but .024 inches.
07-26-2006, 11:43 PM
1960 24' Tradewind
santa barbara
Safari Tim,
andy is correct on the bellypan thickness ,some have had trouble on a shell
off using thicker bellypan aluminum and the shell won't fit back around it.
So what are the plans then for those removed items as in different locations or usage of the trailer?
Scott
07-26-2006, 11:52 PM
1960 28' Ambassador
Northern
When I cut my belly pan loose, I left several inches near the edge so I can rivet to that and not have to fold up to the sides. So the parts I'm replacing will be relatively flat.
I am replacing the water heater and furnace with a Precision Temp TwinTemp. (See the contributor section on www.theVAP.com) It's a continuous tankless water heater and furnace in one unit. Will take up the space a little larger than the water heater did. Only it vents out through the bottom of the trailer, not the sides.
I'm planing on replacing the oven with a convection microwave and a two burner stove top. I'll be redoing the counter top to fit it all together. The microwave will be framed into where the oven was.
Gee, it sounds like a lot more work the more I type it out!
Originally Posted by scottanlily
Safari Tim,
Scott
07-27-2006, 12:59 AM
1960 24' Tradewind
santa barbara
Oh yeah ,how could I forget that part ,I did the same as well .Sounds like you
have some good ideas cooking there .with all this heat I been thinking about roof a/c ,Im starting to check out the options ,would like to fabricate an
aluminum shroud to match the trdwnd ,vintage looking ,for a low profile unit.
somthing with rounded curves airstream like shape ,a smooth flowing look.
well ,time to put ideas to work.
Scott.
07-27-2006, 01:09 AM
1960 28' Ambassador
Northern
Scott,
Talk to flyfshr. He put a new Penquin on his 59 Tradewind. He had to run power to it and have an opening cut.
I'm leaning toward that myself with a 15k btu unit.
Scott.
07-27-2006, 01:26 AM
1960 24' Tradewind
santa barbara
Thanks Tim ,
I will give him PM there and find out the scoop .I don't need a giant unit .
But it would be more enjoyable in the hotter weather having some a/c.
I wiil have to make some modifications but they will blend in or become part
of the airstream look ,maybe an outside drain enclosed in a rivited half tube
flanged housing going down ,yet say 3/8 in size ,somthing small and cool
looking ? I don't know yet ,I see what flyfshr did first
Scott
