Old 03-06-2010, 06:09 AM   #1
1986 32' Excella
Punta Gorda , Florida
aluminum repair
Has anyone out there had experience with buying and replacing the outside upper corner panels on airstreams? My was damaged and I can't locate anyone to do this repair except Airstream shops. Costly. Insurance company will no go there. Help!
allynallyn
allynallyn is offline   Reply With Quote
Old 03-06-2010, 08:42 AM   #2
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
It can be done. some one on the forum may be able to give you some info. Last year at the renovation rally in Alburquerque the replaced some panels . Didn't seem impossible. I think I would try it if I need to. I just am not proficient to tell you how but some one may be able to. It would be nice if you could make it to the renovation rally this year in June in Alburquerque this year there will be alot of info disscussed and its hands on!
arodriguez60 is offline   Reply With Quote
Old 03-06-2010, 08:48 AM   #3
allynallyn
Your insurance company, by contract, must pay to repair your Airstream.
They could refuse, if they thought you bought it that way.
To replace the segments, is not a big deal, once to learn how to do it, "PROPERLY".
Unless you know how, step by step, the simple answer
is "DON'T".
Segments cost several hundreds of dollars each, and are not forgiving if you make a mistake.
Old 03-07-2010, 05:49 PM   #4
1996 34' Excella
Sanford , Florida
Send a message via AIM to Folkie53 Send a message via Yahoo to Folkie53
I feel your pain
I had to have mine worked on extensively and could find no one that wanted to or that I could truly trust in our neck of the woods. I bit the bullet and towed it up to Colin Hydes' place up near the Canadian border and told him to just fix it. He and his crew did a great job and I have never been sorry. On budget and under time too. You just can't beat that.
There are two types of people in this world. Those that have an Airstream and those that wish they did. I feel sorry for the have-nots. HEE HEE
Folkie53 is offline   Reply With Quote
Old 03-07-2010, 05:57 PM   #5
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
..you can also remove the interior "end cap" and push the dent out from inside, although you'll probably be left with a slight wrinkle or line where the aluminum has stretched from the denting.. depends on how cherry you want your rig to look... many good threads on both types of repair..
...the repair is also detailed in the Service Manual (what the shops use) which is much more detailed than your owner's manual...they can be hard to find and pricey (40 bucks and up)..
fotochop is offline   Reply With Quote
Old 01-31-2014, 08:36 AM   #6
Brighton , Michigan
I have a small dent in the front of my CCD international. I'm located in Palmetto, FL and would like to find someone to repair the small dent. The small dent is 3x5. any info please let me know
brucebrew is offline   Reply With Quote
Old 01-31-2014, 08:54 AM   #7
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Is the dent a gentle one or is it sharply indented or creased? Depending, you may be able to simple and effectively pull it out with a suction cup.
When we bought our AS, I didn't realize it but there was a dent in the end cap not really visible from the ground - I'm guessing someone was up on the roof and either kneeled or stepped on the end cap, not supposed to do that!
It pulled out very easily with a suction cup puller I have that is maybe 4" diameter. You could likely get one at a Harbor Freight or similar.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-31-2014, 10:48 AM   #8
Gainesville , Florida
Jd sanders in Alachua just north of Gainesville is an AS dealer and does body work. Jim
Non Airstream aluminum repair help needed Goin camping Off Topic Forum 7 04-09-2007 07:41 PM
Aluminum Repair aviontt Ribs, Skins & Rivets 10 09-01-2004 01:24 AM
aluminum composite countertop repair? Janet H Cabinets, Counter Tops & Furnishings 1 09-30-2003 09:38 AM
Durafix aluminum repair 83Excella General Repair Forum 1 03-22-2003 07:03 PM
Sheet Aluminum repair lee_jachter Ribs, Skins & Rivets 8 11-23-2002 08:48 AM
