Old 11-20-2015, 05:29 AM   #1
Fayetteville , New York
Aluminum Patch Thickness?
I need to patch some small holes in the skin. Is .016 2024-T3 too thin to use? If so, what thickness should I use (.020, .025, .032, .040)?
Whalensdad is offline   Reply With Quote
Old 11-20-2015, 07:10 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
It would help to know what year of trailer you are patching (as 2024 T3 might not even be the appropriate alloy), but .032 is the most common thickness for vintage trailers.
good luck!
Old 11-20-2015, 07:18 AM   #3
It's an AS Knockoff built in the early 1940's. I don't have a clue what the current thickness is.
Old 11-20-2015, 07:47 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
.032
Old 11-20-2015, 12:49 PM   #5
Is there any reason not to use a thinner sheet? I'm only using it to cover very small holes and damage?
Old 11-20-2015, 02:13 PM   #6
Belegedhel's Avatar
Houston , Texas
Whether you want the patch to be purely aesthetic, or structural, I would suggest thicker (.032) is better. From the aesthetic point of view, if you use something very thin, it is more prone to rippling/deformation just from the process of riveting it in place. From a structural point of view, If you expect your patch to transfer the shear loads being experienced by the rest of the shell, then you should make it of the same material.
Old 11-20-2015, 02:37 PM   #7
Thanks for the explanation. I never thought of those points.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
To patch or not to patch... truckirwin Repairing/Replacing Floor &/or Frame 8 05-01-2014 05:18 AM
What thickness aluminum for interior wall coverage is good? and where 2 buy it? LAWFISH Interior Restoration Forum 10 03-07-2014 02:28 AM
Aluminum Grade and Thickness BigGrey Interior Restoration Forum 0 05-14-2012 10:45 AM
Body mods: To patch, or not to patch? Belegedhel Ribs, Skins & Rivets 0 01-05-2012 09:33 AM
Aluminum sheet thickness/type crispyboy Ribs, Skins & Rivets 2 05-29-2007 01:58 PM
