Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 10-16-2006, 07:31 AM   #1
crispyboy
crispyboy's Avatar
Profile:  1981 22' Excella II
alexandria , Kentucky
Aluminum panel cost
I was looking at this trailer over the weekend as a possible purchase. It has two very big dents. Can you still purchase these panels? From whom and a general idea of what they may cost. This will be a DIY project.
ID:	27056  Click image for larger version
crispyboy is offline   Reply With Quote
Old 10-16-2006, 07:54 AM   #2
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
No they are only avail in plastic, if you search you will find pic's of someone taking two pieces of wood cust to the curve of those parts and tapping them out.
Cost= $0
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 10-16-2006, 08:00 AM   #3
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
that would be me, here
http://www.airforums.com/forum...air-24690.html
othes have chimned in and said that using lead shot bags or some such autobody tool would allow for even smoother results. I was in a hurry and justified my shoddy work on the fact that the banana skins are doomed to be dinged now and then.
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 10-16-2006, 08:12 AM   #4
airstream4
airstream4's Avatar
Profile:  1997 34' Limited
1963 22' Safari
Troy , Michigan
You are asking more than one question, The panals are available, formed panals with compound curves must be ordered thru a dealer and cost approx $500 each, flat panals on the sides can be ordered from an aluminum supplier. The panals on the bottom rolled into the bottom plate and covering the frame may only be available in plastic for the corners but straight sections are plain aluminum. Look in the ribs and skins section of the forum some repairs are very extensive and list the tools and methods used by DIY.
Good Luck!
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 10-16-2006, 08:23 AM   #5
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
On the street side rear dent, I've been told only the upper panel is compound formed, the lower one is a simple bend in Alclad .032 sheet stock. RV salvage yards may be able to supply you with one compound panel but the the hassles of re-fitting the used panel would probably be costlier than outright purchase of the formed panel...
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Old 10-16-2006, 08:32 AM   #6
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
The lower banana wrap dent isn't too bad in the first place. It could be gently hammered to a more regular contour if you end up disassembling. I did that on my Argosy and the result is quite good. I suspect rivet holes may need to be re-done. The belly skin may be corroded thin anyway, but doing a small belly skin patch will be out of sight if necessary.
The roadside rear corner is more severe. I've seen repair manuals for some years that have diagram of each component and panel number. Availability? If available it is very expensive -- any Airstream dealer could get that info for you. Might be tough for a DIY-er. Even worse is that this is a major disassembly and requires a fairly high level of experience -- but I think many would be able to manage this if they're handy in the first place. Aluminum stretches when it gets dented, so hammering this out is not an option.
A novel but workable approach is bondo bodywork and repainting the whole trailer. Can't lay my fingers on it but there have been some member photos -- a silver/aluminum painted Airstream is darned hard to distinguish from the original. I have seen member BigAl's Airstream that was painted due to some metal issues. He doesn't maintain anything in the photo section here but it looks good.
Old 10-16-2006, 09:39 AM   #7
crispyboy
crispyboy's Avatar
thank you for the quick replies.
As you can see from the finish on the trailer it is in poor condition. I figured that I would probably paint the trailer anyway. This thing needs a lot of work like axles (easily done), tires, a/c shroud, new cushions, curtains, shades, screens.... but it has good points of being close to home, good floorplan, no rear end seperation and kind of what I'm looking for. It is located at an Airstream dealer but I still think their price is way out of line. They have given me a line of bull that cleaned up it would be worth 10,000 to 12,000 dollars. I was ready to give up at that point. They would sell for $4000 - I walked away.
I have been studying the posts on this board for quite awhile - thanks everyone for you information.
aluminum question MsLed Ribs, Skins & Rivets 12 01-15-2003 09:21 PM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 08:28 PM
Sheet Aluminum repair lee_jachter Ribs, Skins & Rivets 8 11-23-2002 08:48 AM
Polishing...approx cost? Drew Cleaning, Stripping & Polishing 9 09-16-2002 08:00 AM
Aluminum Tanks uwe 1970-76 Tradewind 2 07-17-2002 01:56 PM
