Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 06-01-2002, 06:56 PM   #1
74Tradewind
74Tradewind's Avatar
Profile:
Question Alum. Skin Repair
Is there an easy way to make presentable repairs of the aluminium skin where old rivets were once placed?
Other than installing another rivet, can this 1/8" hole be welded and ground smooth? Is there a filler to use? A previous owner took off the old window shades and installed ZipDee awnings on four sides of the trailer leaving the awning holes some with rivets.
Brian
74Tradewind is offline   Reply With Quote
Old 06-01-2002, 09:08 PM   #2
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Brian;
I think you answered the question yourself. Olympic rivets would be your best repair. They can be had in lots of 100 for about $15.00 US. Just apply a little dab of Vulcem in the hole or on the rivet, pop the rivet and grind the head with a file or dremel. It will look like a Pro did it.
Fillers will shrink and crack pretty quick.
Welding would costs you a bunch of bucks plus you would have distortion and you would never get the patina of the aluminum to match. Notice any other welding on your Airsteams skin? There is none.
Regards;
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Skin replacement Ken J Ribs, Skins & Rivets 285 09-28-2008 04:31 PM
Skin Repair newae Ribs, Skins & Rivets 10 03-13-2004 11:35 AM
jack nife - front skin repair - parts ? JimWeed Ribs, Skins & Rivets 3 12-31-2003 01:01 PM
Recommendation for skin repair in Northeast? rluhr The Vendor's Forum 5 08-28-2003 10:14 AM
Belly skin removal Pat McSween Belly Pans & Banana Wraps 1 05-17-2003 08:23 AM
