Old 07-08-2014, 03:40 PM   #1
Portland , Oregon
Air Rivet Tool Suggestion
I am going to be using Olympic, and pop rivets galore.
1952 Silver Streak Clipper. Inner skin replacement, belly pan, and at least 3 outer panels.
No bucked rivets.
Need a good air tool. Any one tried the $70 Harbor Freight one. Not the cheap $40 one.
Robert
bikeukeguy is offline   Reply With Quote
Old 07-08-2014, 03:47 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I've got the cheapo HF pop rivet tool. I've reinstalled my bellypan and my interior with it, and haven't had any problem.
Old 07-11-2014, 07:38 AM   #3
Belegedhel's Avatar
Houston , Texas
Murphy must have been watching when I submitted that post...I went to use my air riveter last night, and the main valve was sticking, disassembled to find one of the rubber valve components shot, and no replacement in the kit of seals and spare parts that comes with the thing. What to do...
Old 07-11-2014, 09:29 AM   #4
1981 31' Excella II
New Market , Alabama
If they are 1/8" rivets just use a manual tool. You don't want to install 3/16" Stainless rivets with a hand tool.
Perry
Old 07-11-2014, 12:16 PM   #5
aquinob's Avatar
Portsmouth , Virginia
I've been using the 40 dollar one, hope Murphy doesn't get me cause it works pretty good. Definitely does better on the smaller 1/8" rivets than the larger ones, but even with occasional jams, its much faster overall and it saves the muscles in your hand.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 07-11-2014, 12:29 PM   #6
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
I have been using the bigger one for years. It certainly isn't an "everyday" tool, but I've had very good luck with mine.
I reassembled just about every interior panel of my Safari with it.
Obviously, use a 25% coupon!
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 07-11-2014, 02:32 PM   #7
DFlores's Avatar
1968 22' Safari
I have been using the blue one from Harbor Freight, accomplished belly pan install with 3/8" big head rivets, shell install using 1/8" pop rivets and inner skin install using 1/8" rivets. The thing is still going, saved my hands for sure. Just watch that each discard shaft comes out, I didn't and had to take apart and fish out about 4 shafts stuck in line...it's easy just look down the barrel looking for daylight
DFlores
David & Diana
DFlores is offline   Reply With Quote
Rivet removal tool campcollector Ribs, Skins & Rivets 18 07-25-2013 09:52 PM
Need Loaner Tool: Olympic Rivet Shaver jmpratt General Repair Forum 9 05-03-2012 09:18 AM
US tool rivet shavers zgears Ribs, Skins & Rivets 2 04-17-2012 06:35 PM
50's Hehr roof vent lifter arm rivet tool vintageair Roof Vents, Skylights & Fans 12 06-29-2011 01:37 PM
Best rivet tool? Andy R Ribs, Skins & Rivets 9 09-24-2006 07:36 AM
