Old 10-24-2010, 07:15 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Advice on Repairing Small Holes in Skin
See the pic on two small holes in my Overlander. These holes were from a couple of mounting bracket screws for a side mount TV antenna. It looks the bracket was simply pulled out, damaging the skin around each hole. As you can see the holes aren't simple holes. The bracket when it was pulled out tore the edges of the holes. Any advice on getting these tears flush? Once I get these flush, I will repair the holes with a couple Olympic rivets.
Thanks in advance.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 10-24-2010, 08:04 PM   #2
pbearsailor's Avatar
Port Hadlock , Washington
With those tears in the skin, I think it's unlikely that Olympics could seal those holes. I'd be thinking more along the lines of a couple of small round aluminum patches riveted on.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 10-24-2010, 08:17 PM   #3
r carl's Avatar
Lin , Ne
If you could hold a steel block behind the holes you could hammer the holes flat and use big rivets. Without access to the back side, you could screw 2 stainless screws with vulkem on the threads into the holes and wipe off the excess vulkem.
Old 10-24-2010, 08:19 PM   #4
x
XXXX , XXXX
Mike I agree a patch is the best way to go. I`ve seen some others cut a patch in the shape of their home state and that way the patch looks intentional and not to cover up a hole. Would the area in question lend itself to such a patch.
wasagachris is offline   Reply With Quote
Old 10-24-2010, 08:40 PM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Depending on the hole size it can be dimpled and a soft flush rivet installed. Drill a hole in a rivet set to accept the male die and a hole in a bucking bar to accept the female set and shoot like a rivet. This will make a dimple in the skin that a MS20426A5-X will set flush in. Then shoot the rivet with a flush set. The hole will almost disappear. The dies are available in all the standard rivet sizes.
5/32" Dimple Die Set
Old 10-24-2010, 09:10 PM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks for all of the replys.
I was hoping I could repair these two holes without removing the inner skin, but it doesn't look like that's going to be possible. A bucking bar behind the skin and lightly pounding the tears down is probably the best way to go.
Aerowood, your idea is intriguing. Your method would require removing in the inner skin also, correct?
1958 Overlander
4CU 1st VP
Old 10-24-2010, 09:41 PM   #7
Dag68's Avatar
1965 22' Safari
Shelter Island , New York
Images: 20
I see a panel located below the tears but I'm not sure what that is. Would removing that panel (and later re-riveting it back) give you enough access to brace the back of the tears while you smooth them? What else is around your damage?
Come on a (1965) Safari with me!
Dag68 is offline   Reply With Quote
Old 10-24-2010, 09:59 PM   #8
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
This may work....they make aluminum fairing washers. Get some (pick a size) and smooth out the rip/hole. Install the washer...it will lay flush....and fasten it with an Olympic rivet. Don't forget the Vulkem... The washer will polish out like the dressed Olympic.
Cessna 'Fairing Saver' Washer Stainless For No. 8 screw on eBay.ca (item 290252800921 end time 31-Oct-10 11:16:01 EDT)
Old 10-27-2010, 02:38 PM   #9
Aerowood's Avatar
Arvada , Colorado
Yes
Holes in skin bwaysteve Ribs, Skins & Rivets 17 01-30-2010 07:33 PM
Get rid of those holes-skin replacement markdoane Ribs, Skins & Rivets 6 09-28-2004 06:43 PM
Screw holes in my skin 58BUBBLE Ribs, Skins & Rivets 11 09-12-2004 09:53 PM
holes in the skin bhsl8 Ribs, Skins & Rivets 7 01-06-2004 05:52 PM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 07:01 AM
