Old 04-14-2009, 05:21 PM   #1
navyeod's Avatar
1958 26' Overlander
1991 29' Excella
auburn , Alabama
Advice on fixing this dent
I would appreciate some advice on fixing this dent in a 91 29 excella that I just purchased.
navyeod is offline   Reply With Quote
Old 04-14-2009, 05:30 PM   #2
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
I have a similar dent on the other side same location. Its smaller so i think i can live with it but knowing me i will tackle it some day. If you could get behind the inner wall you might be able to press it out somewhat. Maybe make it look a bit better.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 04-14-2009, 05:36 PM   #3
Trying to push it out would more than likely make it look worse.
Replacing the quarter panel, is the only real fix.
Old 04-14-2009, 06:08 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Is that some kind of patch over it? Is the patch covering a tear? You may be able to pull it out somewhat with a "Ding King" and may be able to roll it out from the inside witn a bed frame rollerif you take off the interior skin. But, for a perfect fix you will need to replace the panel
Old 04-14-2009, 06:46 PM   #5
navyeod's Avatar
1958 26' Overlander
1991 29' Excella
auburn , Alabama
Patch
I talked to the PO and there was no tear. He just put some aluminum tape over it. Dont really understand the reasoning. My guess I will have to heat it up when I get a chance and see if I can get it off.
Old 04-14-2009, 07:18 PM   #6
moderator
Airslide's Avatar
Wilton , California
Images: 50
I actually worked with some dent pro tools on a panel in the right front. The results were pretty good. Most people dont notice it unless the light hits it just right or i point it out. Worst case i guess you could have the panel replaced but why not try if your going to do that anyways..
Vin
Old 04-14-2009, 07:25 PM   #7
Benjo's Avatar
1949 18' Trailwind
Huntsville , Alabama
david-benjo here...nice to meet you too. hey, i know where you can get that panel replacement. pm and i can pass you some info on it. actually he's not too far from you. also, check my blog for trailwind pics. met an older guy today that owns a 48 or 49 liner. just sinking in his backyard. he also has a 78 airstream back there as well. take care, -b
Benjo is offline   Reply With Quote
Old 04-14-2009, 07:26 PM   #8
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My immediate concern is that dent looks like a path for water to get onto the rear floor of the trailer.
Richard
Old 04-14-2009, 07:37 PM   #9
navyeod's Avatar
1958 26' Overlander
1991 29' Excella
auburn , Alabama
Water path
Richard. My concern too!!!! May be doing some tearout this weekend to see.
Old 04-14-2009, 07:38 PM   #10
navyeod's Avatar
1958 26' Overlander
1991 29' Excella
auburn , Alabama
Benjo
Great, GREAT trailer. That is going to be so cool. Loved the pics on your blog. I will pm you. david
Old 04-14-2009, 07:43 PM   #11
somefun's Avatar
1974 27' Overlander
Puyallup , Washington
I wonder if you could take off the trim, remove the banana wrap and slide something up behind the panel from the outside and push it out. I have a similar larger dent on the other side, and have thought about maybe trying that approach...
somefun is offline   Reply With Quote
Old 04-16-2009, 09:03 PM   #12
navyeod's Avatar
1958 26' Overlander
1991 29' Excella
auburn , Alabama
Aluminum Tape Repair
Now I see the purpose of the tape.
ID:	78566   Click image for larger version
Old 04-16-2009, 09:13 PM   #13
Utahgoldrup's Avatar
1991 25' Excella
Salt Lake City , Utah
Wow... that is painful to see. I would think replacing the whole panel/skin would be the best fix, I am sorry to see you have to deal with this. I certainly wish you luck in taking care of this. I wonder what caused this damage?
Utahgoldrup is offline   Reply With Quote
Old 04-16-2009, 09:51 PM   #14
moderator
Airslide's Avatar
Wilton , California
Images: 50
Rut Row.... sorry to see that under the tape. It seemed too good to be true when the PO told you that he just put the tape over it.. over what? well now we know. Looks like she is going to get a new section. What about that fix for the rear end sag. It kinda looks like elephant ears on each rear side. Maybe its cheaper and would suffice. Maybe it just wouldnt look right either. I dont know where the picture is. Maybe someone can find it.
Vinnie
Newbie needs advice on fixing rotten floor Lyvettely Repairing/Replacing Floor &/or Frame 32 11-26-2014 01:48 PM
Help! I need advice on fixing a big dent. Deborah Penn Member Introductions 18 06-08-2008 07:42 AM
Fixing a Dent Muddy Waters Clearcoat, Exterior Paint & Trim 21 05-30-2008 10:59 AM
Fixing this Dent - How about this approach? mello mike Exterior Restoration Forum 10 09-15-2005 09:14 PM
thanks for the advice on the dent wayne.yl Ribs, Skins & Rivets 8 11-07-2003 05:23 AM
