Old 05-06-2011, 08:53 PM   #1
n8andm's Avatar
Minneapolis , Minnesota
Advice for removing these window rivets
I just purchased an old window and I have to remove it from the skin. I thought I could practice my removal methods on this piece, but the rivets are big. Take a look. What are the best tools to use for this? I know that Vintage Airstream Supply is having a sale on riveting kits right now, would you advise ordering one of these, if so which one? I have a lot of body panels to work on. The sale ends tomorrow, but I am fine buying used equipment too, I just need recommendations! Thanks in advanced.
_______________
/.:N8andM.in.MN:.\
|:Silver Streak Jet:|
n8andm is offline   Reply With Quote
Old 05-07-2011, 06:57 PM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
The website takes way too long to load. I got bored waiting. Best to post the pics here.
Drill for removing rivets.
For buck riveting you are pretty much going to need everything that VTS has in their kit plus an air compressor.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 05-07-2011, 08:05 PM   #3
n8andm's Avatar
Pic of my rivets
I'm trying to figure out this image thing, got to upload to server.
Here are the rivets that I'm not sure how to remove. Do I drill the flat side or the round side? It's so intimidating.
_______________
/.:N8andM.in.MN:.\
Old 05-07-2011, 08:12 PM   #4
DanielB's Avatar
I'd say round side, but flat side might be easier. Try one of each and see which is easier.
Do yourself a favor and take a nail punch, or, a 16 penny nail might work, and knock a dimple in the middle of each rivet so that the drill has somewhere to go. That will help to keep the drill bit from sliding off of the rivet as you are drilling.
I understand that it is intimidating, but really it isn't that bad. You'll see. Just don't get in a big hurry and try to force anything. One rivet at a time and don't be afraid to adjust your procedure.
- Andrew Carnegie
Old 05-08-2011, 08:58 AM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Drill from the manufactured head or "round size" using a #30 drill bit.
Old 05-08-2011, 09:37 PM   #6
n8andm's Avatar
Thanks everyone, I'll give it my best!
_______________
/.:N8andM.in.MN:.\
Old 05-13-2011, 08:09 AM   #7
Tool Hoarder
West , California
For the solid rivets I used this tool. It worked great for me Aircraft Tool Supply | RIVET REMOVAL TOOL | 1341A
marzboy is offline   Reply With Quote
Old 05-13-2011, 07:37 PM   #8
n8andm's Avatar
Thanks, now I'll have to see how much that goes for. New tools are a fun treat!
_______________
/.:N8andM.in.MN:.\
Old 05-14-2011, 04:18 PM   #9
n8andm's Avatar
Rivets are removed! After a couple hours of hammering the flat heads off the rivets, I have finally removed all the ones still attached to the skin, 87. Some where holding 4 layers together and had to be chiseled off again. The evidence is only seen from the back side of the window, and my sore hand that was hammered accidentally a few dozen times.
_______________
/.:N8andM.in.MN:.\
rivet, window replacement
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
