Old 06-07-2007, 05:52 PM   #1
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
A rivet fell out!
Cleaning the Safari SE after a trip we found a rivet on the floor. It came out of the interior wall near the door. I guess I'll have to figure out if it just held two sheets of aluminum or it it also anchored to a stud of some sort. It looks like a regular old pop rivet, but I recall reading discussions about types of rivets and am not sure if that was just an interior/exterior thing. Any suggestions?
Old 06-07-2007, 06:02 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The interior is riveted with pop rivets. Try another one in the same place.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-07-2007, 06:39 PM   #3
Wayne&Sam's Avatar
Images: 21
Thanks.
Old 06-07-2007, 07:38 PM   #4
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
Wayne&Sam,
From our experience that is very normal. Especially above the door. I would have your dealer replace it under warranty (being done on ours right now). I have a theory that it is related to frame flex when using a weight distributing hitch.
-KL
4CU Charter Member
silverback is offline   Reply With Quote
Old 06-07-2007, 08:06 PM   #5
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Might also want to check the balance on your tires.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 06-08-2007, 04:03 AM   #6
Wayne&Sam's Avatar
Images: 21
The rivet is maybe 3/4" long, so I don't think it just held two sheets of metal. Either it went through something else and the long shank allowed enough flex for it to fail or it just wasn't put in right.
Dealer is nearly three hours away so maybe I'll call get their advce and just pop a new one in.
Old 06-08-2007, 06:44 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Make sure you use an aluminum rivet, you don't want to start dissimilar metal corrosion on such a young trailer.
I had to replace quite a few rivets in our trailer, none had ever been replaced.
The advice about tire balancing is sound, even if they were factory balanced, one or more tires could have shucked a weight, causing a vibraqtion., Lost rivets are one of the first signs of out of balance tires and running gear.
Old 06-08-2007, 06:58 AM   #8
2007 25' Safari FB SE
Burien , Washington
Did you find where it came out? We took delivery of a new trailer and after a couple trips I found a rivet head on the floor, but haven't located where it came from yet. I am thinking it was left over debris from the factory. I found a lot of shavings and stuff like that. It made me thing the factory had a few slobs working for them. That subject is for another thread...another day.
Sam
SRoffe is offline   Reply With Quote
Old 06-08-2007, 08:22 AM   #9
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
The purpose of rivets is to secure the metal to an internal trailer rib or other support structure in the trailer. The only time you will see rivets holding together two sheets of metal is when someone missed the rib but the rivet will probably haven fallen out by then!
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 06-08-2007, 10:14 AM   #10
Wayne&Sam's Avatar
Images: 21
Sam- yes we found the hole with the misiing rivet.
Yukionna- Yes, it is at a place when sheets are not over lapping. Also, the length of the rivet makes me thing it's grabbing soemthing that's 3/4" away from the sheetmetal. I'll check it out over the weekend.
Old 06-08-2007, 10:14 AM   #11
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Saw the same thing on a brand new 2006 25' FB unit at an RV show. It was missing the rivet up near the front entry door on the ceiling....of course, even Artisans (as Airstream calls them) can't always be 100% on the rivets.......
Old 06-08-2007, 12:52 PM   #12
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
POP goes the Wheezel
Invest in a hand pop rivet gun (under $50 bucks) and an assortment of Aluminum pop rivets. You'll be surprised at the many uses you will find for it.
Michael
ArtStream is offline   Reply With Quote
Old 06-08-2007, 01:04 PM   #13
Wayne&Sam's Avatar
Images: 21
I have a pop rivet tool, I'm just concerned about re-riveting it blind- not knowing if I'm catching the right pieces inside the wall. It would be nice to know the construction in there.
Old 06-08-2007, 04:26 PM   #14
yukionna's Avatar
Massachusetts
Images: 18
I wouldn't worry about it...I would just do it (as long as you know how to use the rivet gun and to choose the correct size and type of rivet). You aren't going to hurt anything (the hole is already there, right?).
You can tell where the ribs are by looking at the line of other rivets. Start on the outside and it is easy to see.
WBCCI Region One
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
Best rivet tool? Andy R Ribs, Skins & Rivets 9 09-24-2006 07:36 AM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Rivet Lounge PeterH-Airstreamer Our Community 68 09-24-2002 11:22 PM
