Old 09-20-2012, 05:16 PM   #1
Jim & Mitzi's Avatar
1990 34' Excella
1990 29' Land Yacht
Americus , Also Valrico, Fl
'77 31' IS mid bath front panel below window
Above AS has 2 battery boxes just outside of the frame rails. below the center front window. There is vent just below the window ~ 3" x 12" W. The aluminum panel between the battery box doors and just below the vent appears to be recessed approx 1". This recessed area appears too smooth to be a dent and the interior ribs seem to be placed to support the recessed area. Is this recessed as from the factory or a well applied accident / dent ? All the surrounding panels seem fine. The inner edges of both battery doors are going to be difficult to reinstall due to the curvature of the center panel. H E L P
Jim & Mitzi is offline   Reply With Quote
Old 09-20-2012, 05:52 PM   #2
1977 Argosy 24
Milltown , Wisconsin
Pictures would really help get better answers to your problem.
ventport is offline   Reply With Quote
Old 09-21-2012, 06:18 AM   #3
1990 34' Excella
1990 29' Land Yacht
77 front below window panel
Trying to add pix ASAP Thanx
Old 09-21-2012, 07:07 AM   #4
Ottawa , ON
Have a look at Janet's thread on photo posting. You'll find lots of good advice on how to do it there.
http://www.airforums.com/forums/f138...tml#post612569
ďCourage is being scared to death, but saddling up anyway.Ē
Old 09-22-2012, 04:03 PM   #5
1990 34' Excella
1990 29' Land Yacht
77 as mid bath
front panel between battery doors recessed / dented ? Too smooth to be a dent ?? Pix added I hope
Name:	Misc  AS. kids  etc fall 2012 101.jpg
ID:	168815   Click image for larger version
Name:	Misc  AS. kids  etc fall 2012 100.jpg
Old 09-22-2012, 07:44 PM   #6
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
That's most definitely a dent...
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 09-23-2012, 07:39 AM   #7
1990 34' Excella
1990 29' Land Yacht
Angry dent tween battery box doors
I wish i could disagree about dent. Absolutely no sign of impact anywhere in the area. "Studs" behind not bent. ???? We'll get er straighened, sealed and whatever it takes. Many thanx J & M...
Old 09-23-2012, 08:25 AM   #8
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
What a strange location for a dent!
Skatiero is offline   Reply With Quote
Old 09-24-2012, 10:51 AM   #9
1981 31' Excella II
New Market , Alabama
I expect there was something like a tire that was wedged behind there and it got hit during a jack knife event. This needs to be fixed because there is a steel hold down plate between those boxes that is probably bent or detached. I expect the coucho will have to come out and at least the front inside center panel. That area is important because it is the main structural attachment area where the shell attaches to the frame.
Here is a photo. You can see the steel plate between the box openings. To the outside of each box is also a bolt on the other side of the vertical stringer. This bolt needs to be intact and tight as well. I expect the stringers on the inside of the boxes are damaged as well as the outside ones. The panel looks like it may pop out once the structure under there is fixed.
Perry
Old 10-29-2012, 01:10 PM   #10
1990 34' Excella
1990 29' Land Yacht
Odd dent below front window
Not sure what caused the dent...Possible dropped front end off jack or block. To fix it...I realized there was too much metal from the bottom of the window down to the frame. I removed all the rivets below the window and down to the frame and between the battery doors. As I was removing the final few rivets the front metal "Dropped" slightly and the dent just about disappeared. Re-riveted and some to relocated holes and all seems well. Had to do something....There sis no apparent frame damage or bends in the frame. All seems plumb. But obviously something caused this movement. Thanks to all. Jim & Mitzi
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
Removing shower from 1974 Soverign 31" mid bath? 74yachtpnw Sinks, Showers & Toilets 1 11-07-2011 03:02 PM
Relocate bath GaCamper Sinks, Showers & Toilets 4 05-14-2011 04:56 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
1975 Sovereign right front window Jim in Pima Windows, Doors, Locks & Vents 3 04-24-2011 07:51 PM
