Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 11-07-2006, 10:49 PM   #29
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
floor out
I took the aft two floor panels out this afternoon. These two panels have extensive acid rot from PO battery boil over. Also found rot around lav. Removed the Galvenized portion that caused the skin corrosion. Last but not least started making new floor panels. Still need to clean up frame and apply the POR-15. I have also started my search for a gray water tank. I,m going to put it betwwe the crossmembers aft of the axle. The fresh water tank sets just in front of the axle. Looks like I can get around a 25 gal tank to fit there. The search continues.
ID:	28311  Click image for larger version
Old 11-08-2006, 09:13 AM   #30
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
looks like your well under way to a nice repair
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 11-17-2006, 09:38 PM   #31
Aerowood
Aerowood's Avatar
Arvada , Colorado
update
I got the frame cleaned up and applied POR-15 last weekend. cleaned it on Sat. and painted on Sun. I no sooner got started when it started snowing. I sprayed on the POR-15. It went real well except I think I froze my trailing edge off. Got the two floorboards cut out and I recessed the area that goes over the wheelwell so the floorboard would set flat. I also found the outrigger that is fwd of the rt. wheel well broken off and bent up. Both of the wheel wells were cracked also. I am now ready to reinstall the repaired outrigger and wheel wells. I also made new U channels and all the coroded parts (except skin) that I found bad on the rear. Busy day tomorrow
ID:	28734  Click image for larger version
Old 11-17-2006, 09:40 PM   #32
Aerowood
Aerowood's Avatar
Arvada , Colorado
pics
For some reason I cannot upload more then 3 pics
Old 11-17-2006, 09:42 PM   #33
LI Pets
Silver Mist
LI Pets's Avatar
nice work, have a fun weekend.
WBCCI
Old 11-18-2006, 01:53 PM   #34
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Damn nice work! I didn't think you'd be going so fast. You'll have the whole thing done in time for spring camping. Envy envy envy....
Yes, you can upload more than three. After you browse and select the first two or three, upload them. Then just browse again--repeat until you get up to 8 (it's 10, had to look) uploaded. When you go to your paperclip icon to insert the images, you'll see that they are all there.
I don't know why the browsing function stops uploading if you've selected more than 3--maybe there is a total file size limit for each upload. I just deal with it by doing multiples.
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 11-18-2006, 08:19 PM   #35
Aerowood
Aerowood's Avatar
Arvada , Colorado
I installed the floor panels today. I now need to put all the U channel down and get the skin clecoed back on
ID:	28771  Click image for larger version
Old 11-19-2006, 11:43 AM   #36
AirstreamGypsy
AirstreamGypsy's Avatar
Profile:  1961 16' Bambi
Mancos , Colorado
A question
Is it wise to put the pergo floor in befor the interior walls? If so why?
May your Travels be Many
In the Journey that is Life
AirstreamGypsy
___________
AIR # 11128
WBCCI # 1818 - VAC
Charter Member FCU
CP
(Courtesy Parking)Wi-Fi
http://www.sdgraphics.net/myearthship/
AirstreamGypsy is offline   Reply With Quote
Old 11-19-2006, 07:05 PM   #37
Aerowood
Aerowood's Avatar
Arvada , Colorado
The picture you are seeing is just the the plywood with several coats of gloss poly that I had left over from another project. I had tinted the poly with a light maple stain. The bottom looks just as good except for the knots.
Old 11-27-2006, 07:49 AM   #38
Aerowood
Aerowood's Avatar
Arvada , Colorado
update
I got the U channels all down (forgot to take camera) and replaced the rear doubler that was corroded so bad. I will start replacing the rear skins with a favorable weather forcast.
Old 11-27-2006, 12:38 PM   #39
doorgunner
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
interior flush panels
I've also been considering flush joining interior skins. Was thinking of using Hysol to bond a backing strip on one panel and then flush rivets on the joining panel- fewer rivets. Or possibly nutplates(K-1000) with a finish washer and oval head screw in area's where I might desire an inspection plate or access to elect- etc. Nice Avitar- pretty cool flyin with the doors open. Tim
www.popasmoke.com
Proud Appellation American
doorgunner is offline   Reply With Quote
Old 11-27-2006, 01:52 PM   #40
Aerowood
Aerowood's Avatar
Arvada , Colorado
I was also thinking nutplates, but the dimpled style, and then dimpling the skin, but I haven't made up my mind yet. It would be alot of nutplates.. We fly with the back open alot, generally with satilite proof of concept instruments or in this case it was a prototype hurricane bouy that we launched into a lake in Oklahoma.
Old 11-27-2006, 05:12 PM   #41
doorgunner
INSANITY CENTRAL
doorgunner's Avatar
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
another open door shot
Lets see if this works. I tried to PM and Email this to you with no joy. try it here.
www.popasmoke.com
Old 02-27-2007, 02:55 PM   #42
Aerowood
Aerowood's Avatar
Arvada , Colorado
Well the weather has improved enough for me to start re-skinning part the Globetrotter. I removed the aft lower skin this morning and will take to work tomorrow to fab a new one.
Doin' the Full Monte Jim & Susan 1973 Overlander 623 Today 09:17 PM
Avoiding the full monte (we hope); Overlander redo/repair blackboat 1970 Overlander 9 07-18-2006 08:39 PM
Missing Outriggers!!- Full Monte??? fly2havefun Repairing/Replacing Floor &/or Frame 9 06-14-2006 12:38 PM
full-timing njoysrvin Full-Timing 5 06-13-2006 10:20 PM
I'm off full-timing! zduke4x Full-Timing 10 03-08-2004 11:06 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum -
