Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 06-17-2008, 05:28 PM   #225
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
stricker plate
I put on a new main door striker. and continuing with my hatred of pop rivets and sheet metal screws I install self locking stainless steel 8/32 Keenserts to install the striker plate
ID:	62501  Click image for larger version
Old 06-17-2008, 05:38 PM   #226
Aerowood
Aerowood's Avatar
Arvada , Colorado
clearance lights
As stated in my last post I don't care for sheet metal screws so I installed sealed nutplates to mount the new LED lights. Below is a photo sequence from stepping up the hole size to #10 for the drill fixture, drilling #40 holes using the fixture, cleaning up filiform corrosion using a 3M bristle cone brush, countersinking the holes using a microstop with a #40 pilot to the final install of the nutplates
ID:	62503  Click image for larger version
ID:	62505  Click image for larger version
ID:	62507  Click image for larger version
ID:	62509  Click image for larger version
ID:	62511  Click image for larger version
Old 06-17-2008, 07:07 PM   #227
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Kip, do you have to seal those nutplates on the backside with Vulkem (or other)? Forgive me if you answered that already.
“Never underestimate the power of stupid people in large groups.....especially when they're near a ballot box.” --annon.
www.nesa.org
Air No. 6427
Old 06-17-2008, 08:43 PM   #228
Aerowood
Aerowood's Avatar
Arvada , Colorado
No, you don't have to, but I will. I also need to seal up the wire hole because the new LED's lights have the wires comming out at a different location.
Old 06-20-2008, 01:37 PM   #229
malconium
Profile:  1973 31' Sovereign
Portland , Oregon
More about the brush?
Can you tell us more about the 3M bristle cone brush? It looks like something that I could use but I have never heard of them before.
Malcolm
malconium is offline   Reply With Quote
Old 06-20-2008, 02:32 PM   #230
Aerowood
Aerowood's Avatar
Arvada , Colorado
Malcolm
Sure they work great at removing minor surface imperfections without digging in. We get them from one of our consumables suppliers. After looking them up they are actually called "Bristle Discs Rolocs" different grits 50, 80, and 120are available.
I found them at these sites
home
Discs and Rolocs
Old 07-12-2008, 03:52 PM   #231
Aerowood
Aerowood's Avatar
Arvada , Colorado
Door of Worms
Have'nt worked on the GT for a while as we have been using it. First pic is at Turquoise Lake, Leadville Colorado. the rest of the pictures are of the door frame. I removed the old skin which was not 2024-T3 as it was dead soft. The door has been reworked (poorly) by a PO. The door must have been in some kind of accident due to all the damage. The pictures tell the story. I am also changing the style of latch. This mod will not be for the faint of heart, as some machining will be required on the door frame along with a new internal stringer. So off to see my buddy Bart, our certified aircraft welder.
ID:	63564  Click image for larger version
ID:	63566  Click image for larger version
Old 07-27-2008, 08:26 PM   #232
Aerowood
Aerowood's Avatar
Arvada , Colorado
Front window
I still don't have my door frame back from the welding shop, so I decided to finish up the front window. I removed the window and then the frame as it had an obscene amount of silicon on the upper portion of the frame. I cleaned it all up, removed the foam gasket, and then cleaned and plugged holes that were no longer needed. I also drilled up a section of extruded piano hinge for the hinge of the not yet fabricated front rock guard, sealed it all up and riveted it all back together. A full day. I'm working alot of overtime right now, so I'm not getting as much done this summer as I would like.
ID:	64593  Click image for larger version
Old 07-27-2008, 10:06 PM   #233
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Kip, looks like the hinge is an integral part of the window frame! Am I seeing it correctly--you only have one side of the hinge installed, eg, the hinge wire is removed?
BTW, is that my wing window or did you put BEDFORDS' in? Did they have a different fit?
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 07-28-2008, 06:52 AM   #234
Aerowood
Aerowood's Avatar
Arvada , Colorado
Zep, The hinge is a separate piece. It's MS20001-8 Extruded Aluminum Hinge. I took the hinge pin out and removed the other half until I fabricate the front rock guard. The street side window is indeed the the outer pane of the dual pane that I got from you. The glass was thicker then the stock unit so I had to go with an injected seal. I have Tomorrow off so I am going to change a partial skin in front of the entry door.
Old 07-28-2008, 07:44 PM   #235
monocoque
monocoque's Avatar
Profile:  1975 29' Ambassador
San Antonio , Texas
Your window looks very much like mine. How difficult was it to remove? What did you plug the holes that were no longer needed with?
Todd
“Complications arose, ensued, were overcome...savvy?”
- Captain Jack Sparrow
monocoque is offline   Reply With Quote
Old 07-29-2008, 09:12 AM   #236
Aerowood
Aerowood's Avatar
Arvada , Colorado
I slighty countersunk both sides of the hole and then shot in a MS20426AX-X (in this case it was a 4-2) rivet, then sanded it flush on both sides.
Kip
Old 07-29-2008, 10:09 AM   #237
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Kip
Nice, Kip...very nice..
Uwe
Old 07-29-2008, 10:20 AM   #238
Aerowood
Aerowood's Avatar
Arvada , Colorado
Zep, here's a closeup of the hinge
Doin' the Full Monte Jim & Susan 1973 Overlander 599 08-27-2008 05:17 PM
Avoiding the full monte (we hope); Overlander redo/repair blackboat
