Old 11-16-2006, 02:27 PM   #1
kamo's Avatar
burbank , California
63 Bambi Aluminum Skin Gauge
Hello,
Does anyone know what gauge aluminum sheet was used for the exterior skin on early 60s Airstreams?
Kamo
kamo is offline   Reply With Quote
Old 11-16-2006, 02:52 PM   #2
Images: 59
0.032"
markdoane is online now   Reply With Quote
Old 11-16-2006, 03:08 PM   #3
kamo's Avatar
So 18 gauge (0.040") would be pretty close?
Old 11-16-2006, 03:44 PM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
.040 is a standard size for 2024-T3 aluminum followed by: .050, .063, .071, .080, .090, .100, .125 etc
Old 11-16-2006, 03:54 PM   #5
kamo's Avatar
Looks like my local metal supply has both 0.032" and 0.040".
Should I go for the thicker one? I'm fixing the belly pan...
Old 11-16-2006, 04:08 PM   #6
Images: 59
No, I would go thinner. The original belly skin is .025". If you use .032" it is hard to make it curl to a 4" radius.
Old 11-17-2006, 08:49 AM   #7
kamo's Avatar
Thanks. I bought the 0.032", and the softer version.
Old 11-17-2006, 09:33 AM   #8
Airstream has used .040 on the lower sheets only in recent year production.
It does add to the shell strength.
Using .040 instead of the .032 for side sheets on older trailers would add to the strength of those shells as well.
Old 11-17-2006, 09:53 AM   #9
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
kamo, i see you live in burbank. where did you buy the aluminum? i've already made a trip out to aircraft spruce in corona to get a rivet tool and was planning on going there for my aluminum panels when i get to that stage, unless there is a supplier in the valley somewhere, i haven't had a chance to look yet.
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 11-17-2006, 10:06 AM   #10
Aircraft Spruce in Corona almost always has Airstream type sheet metal in stock, but we would suggest you call them first, just to make sure you don't waste a trip.
However, the 2024T3 that they sell usually has some scratches on it.
They are 1 block away from us.
Old 11-17-2006, 11:47 AM   #11
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I used .040 to replace a very long side sheet on my 63 Overlander, and found it to be an excellent choice for straight sections. It looks straight and less wavy then the original one was. Installation seemed easier as well, since the material has slightly more integrity and lays flatter than .032
Uwe
www.area63productions.com
Old 11-22-2006, 06:34 PM   #12
Dan Clayton's Avatar
West Linn , Oregon
Images: 14
.032 T2024T3 is used on the body. T2024T3 .025 is used for the belly pan, I can tell you from replacing a couple of belly pans, that the .025 is far eaiser too use and bend. It's not easy getting the pan to bend the way it needs too. In my area a sheet of T2024T3 .032 goes for $175.00 thats a 4'x12' sheet, a sheet of .025 goes for about $80.00.
Dan Clayton is offline   Reply With Quote
Old 11-22-2006, 06:38 PM   #13
Aerowood's Avatar
Arvada , Colorado
It is just 2024-T3, drop the first T and you are right on. 2024 for the alloy and T3 for the heat treatment
Old 11-22-2006, 07:33 PM   #14
Images: 59
The stuff on the sides is also AlClad, the stuff on the bottom isn't.
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
Belly skin alternatives? Sneakinup Belly Pans & Banana Wraps 27 04-23-2004 06:33 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
