Originally Posted by Ken J
Aaron - looks great! Did you remove the blue tape? If so did you get a clean vulcum seal?
Ken
Pretty decent Ken, I had to use tape, forgot to plug the end of the Vulkem tube and had to cut it close to the cartridge
the bead needs a little final finessing with a razor blade, but it sealed tight and I hope no more leaks, at least at that entry point
It is nice having the light back from that Vista View. Maybe I should pull the overhead cabinets and put Vista Views the entire length of the unit ala the VW microbuses of yore....
Aaron
