Old 04-26-2008, 09:05 PM   #21
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Shaving Time Off Rivet Removal
I would say we spend less than a minute per rivet w/o the tool.
Shari, less than a minute WITHOUT the tool! Okay, now I'm getting some real time frames to hope for in the future!
BTW when do you stop drilling? I think I'm drilling to far into the shank. Which is adding to my time.
I'm still not hearing from anybody willing to race me for slowest time ever!
Todd
“Complications arose, ensued, were overcome...savvy?”
- Captain Jack Sparrow
monocoque is offline   Reply With Quote
Old 04-26-2008, 09:10 PM   #22
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
It usually takes as long as a single whack with a hammer takes.
Terry, I'm not sure your method qualifies as a drilling time! But you should definitely get at least honorable mention for the most ingenious rivet removal technique.
Todd
Old 04-26-2008, 09:12 PM   #23
Retired.
. , At Large
My slowest time to date is 2.5 hours. I broke the drill bit off, and had to remove the broken bit before I could continue. It was in an inccessible location, among other complications.
Old 04-26-2008, 09:29 PM   #24
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Terry, stop it. You keep cheating! That's not a drilling time!
I want somebody to step up to the plate with an actual drilling time slower than mine!
Todd
Old 04-26-2008, 09:36 PM   #25
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Maybe if it was a 1/4" stainless steel rivet
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 04-26-2008, 09:48 PM   #26
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
rivet drilling pre-school
Hey, yall weren't all born rivet masters out there were you! Surely there are a few tales of slow drills from those good ole days in rivet pre-school?
Todd
Old 04-26-2008, 10:23 PM   #27
Retired.
. , At Large
Well, there was that one time when the electric drill broke, and I had to hand-drill out several rivets with a dull bit...That took a while... Does that count?
Old 04-26-2008, 10:28 PM   #28
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
hand-drilling stainless steel rivets
Hand-drilling and stainless steel rivets? Hey yall aren't being serious about this! I earned my 3 minutes the hard way!
Todd
Old 04-26-2008, 10:46 PM   #29
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Reminds me of the time I walked to work in the snow. Uphill. Both ways. In California.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 04-27-2008, 04:12 AM   #30
Baltimore , Maryland
I think Shari hit it on the rivet head... stainless, that is your problem. I would be willing to bet a buck that those rivets are stainless and that is why it takes so long. I bet those were re riveted by someone using stainless. Keep going, they will drill out. I do not recommend you shear them with a putty knife. The problem is not scratching, it is the shaft left behind when the head is cut off. Those shafts, will need to be drilled out later or they will impede you putting it all back. I sheared all the rivets holding my belly pan in, before the new pan could be installed, I had to go back and drill off the shaft from the backside. Talk about a pain in the backside... I do not know about your trailer, but in 1962, the rivets hold tight to the back side of the panel. Using a punch removes only 20% of them, the drilling out of that shaft gets to be very tiresome, so just drill them out from the start. If you use a corded drill, it will have more torque to drill out the rivet. Speed is not the important factor. torque is. I use a very heavy Milwaukee hammer drill in the drill only mode. It has a LO gear setting. That thing just eats up those rivets and produces a continuos shaving until the rivet is done. Maybe 30 seconds, tops. I also leave the heads on the drill bit. When the drill bit is full of heads, I toss the bit in the trash. Good bits are a must... Graingers has good quality ones in my opinion.
Old 04-27-2008, 06:24 AM   #31
Images: 59
I think its a good idea to drill about one skin thickness past the head also. If you stop at that point, the expanded part of the rivet that is holding it in the skin will be shelled out, but it still leaves the tail part as a solid chunk. Some of them you can push right on through with a scratch awl, the rest you can pull off from the inside with pliers.
Grab the tail with a pair of pliers with serrated jaws. Give it a little tug and a quarter twist and it will pop out, and bring the rest of the rivet tail with it.
On the other hand, If you drill all the way through the rivet shaft, you end up with just a few shreds of aluminum that you need to dig out with a dental pick.
Old 04-27-2008, 08:15 AM   #32
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
I'm using a number 30 bit. I'll definitely try ordering some the higher quality bits if it will shave a lot of time. Still, I'm thinking an ordinary bit should be fine for a rivet master? Maybe not.
Usually I keep drilling until the bit taps a hole drills completely through the rivet. What I'm left with is usually the head of the rivet still attached to the skin with a hole completely through the rivet. From there I use something to pry the head off slightly. Then a pair of needle nose pliers does the trick to extract the entire head which either breaks away from the remaining shaft leaving the shaft still in the hole. If the shaft remains I use one of the needles on the pliers to slightly suggest it out.
Only occasionally would I end up with a head on the bit. These are the solid buck rivets under discussion. With the interior pop rivets or the larger belly pan rivets I end up with a metal head on the bit every time.
Todd
Old 04-27-2008, 08:25 AM   #33
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
3 minutes to 30 seconds
From 3 minutes to 30 seconds tops with a good bit and drill. My cordless Makita, using a new bit, was producing a continuous shaving most of the time so I wasn't suspecting the quality of the bit. I'll try a drill with more torque and see how much time I can shave from my three minutes.
Todd
Old 04-27-2008, 08:57 AM   #34
1973 25' Tradewind
Romulus , New York
cordless vs. corded or air
Having used all three I prefer the corded. If the bit is walking around the rivit head you may very well be dealing with stainless.I find that 1 or two stainless rivits and the bit is toast. I can usually drill out a rivit in under 15 seconds, any longer the bit is shot, and it is time to turn it around.
jayray5 is offline   Reply With Quote
Old 04-28-2008, 09:05 PM   #35
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
15 seconds! Maybe these were stainless. As I said they were the group of rivets tying the metal plate to the external skin directly around the 7 way connector. How do you identify a stainless steel rivet apart from a 3 minute drill-out?
Todd
Old 04-28-2008, 09:39 PM   #36
Images: 59
. . How do you identify a stainless steel rivet apart from a 3 minute drill-out?
Try to scratch it with a nail. A nail is harder than aluminum and softer than stainless.
Is this YOUR 15 minutes of fame calling? InsideOut Our Community 2 10-18-2007 10:26 AM
Dometic fix took 35 minutes :) Kistler Refrigerators 12 06-15-2007 06:21 PM
Using OnStar phone with Family Share minutes Airstream25 On The Road... 2 07-01-2006 08:32 AM
help!!! i just typed for 20 minutes and my post was lost vbob Airstream Motorhome Forums 4 03-02-2003 08:03 PM
