Old 04-26-2008, 10:32 AM   #15
1973 25' Tradewind
Romulus , New York
good bits
Buy the high speed double sided 1/8" bits in bulk packs of ten from fastenal. They work great and you get twenty sharp cutting bits (10x2) for under ten bucks.
jayray5 is offline   Reply With Quote
Old 04-26-2008, 08:18 PM   #16
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Jayray5, what's you're drilling time using those bits?
I've noticed a good bit, pun intended, of my 3 minutes is being careful not to apply too much pressure with the drill or the bit rides to the side. That's the purpose of the training devices but I suppose the rivet masters don't use training wheels and rely more on experience. As for me I've only drilled out maybe 50 rivets...so far...
Todd
“Complications arose, ensued, were overcome...savvy?”
- Captain Jack Sparrow
monocoque is offline   Reply With Quote
Old 04-26-2008, 08:35 PM   #17
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We haven't used the rivet removal tool...but I just ordered one! If it's anything like the shaver...I'll love it! Even still, I would say we spend less than a minute per rivet w/o the tool.
Center punch > set the bit by turning by hand > drill to pop the head off > after all the heads are off > go back and punch in the shanks with a springloaded center punch. It takes longer to pull all the heads off the drill bit than to actually drill them out ~
If it's a pop rivet it even takes less time because of the hole in the middle. Steel ones take a bit longer...but a sharp bit is key. Occasionally, if you get a spinner, it may take a minute...I usually grab it with needlenose pliers to keep it from spinning...or if there are two of us, one will hold the back of the rivet with the pliers. We removed all the interior lower panels, the back window, rain gutters, door (down to metal bits to replace the screen) and are getting ready to replace the streetside panel on each of our two trailers and a friends in two weeks (30' of aluminum!) - thus the reason for ordering the tool, we'll give it a try!
Shari
Old 04-26-2008, 08:40 PM   #18
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It usually takes as long as a single whack with a hammer takes. I use a shaprened putty knife to lop the top of the rivet off. Only works with aluminum rivets, but it is a great time saver. When I removed the old Armstrong a/c from our Argosy, I had all the rivets off in 5 minutes flat.
Old 04-26-2008, 08:43 PM   #19
InsideOut's Avatar
1956 22' Safari
Images: 108
But don't you have a higher risk of scratching the skin Terry? I'd be afaid the putty knife would slip ~
Shari
Old 04-26-2008, 08:45 PM   #20
Well Preserved
1993 21' Sovereign
Shari
You do, but there is little risk of anyone seeing scratches on the roof of a painted trailer.
As in all things common sense should prevail. If you're removing rivets on belly pan, roof, inner panels, it saves a bunch of time.
Old 04-26-2008, 09:05 PM   #21
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Shaving Time Off Rivet Removal
Shari, less than a minute WITHOUT the tool! Okay, now I'm getting some real time frames to hope for in the future!
BTW when do you stop drilling? I think I'm drilling to far into the shank. Which is adding to my time.
I'm still not hearing from anybody willing to race me for slowest time ever!
Todd
Old 04-26-2008, 09:10 PM   #22
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Terry, I'm not sure your method qualifies as a drilling time! But you should definitely get at least honorable mention for the most ingenious rivet removal technique.
Todd
Old 04-26-2008, 09:12 PM   #23
Well Preserved
1993 21' Sovereign
My slowest time to date is 2.5 hours. I broke the drill bit off, and had to remove the broken bit before I could continue. It was in an inccessible location, among other complications.
Old 04-26-2008, 09:29 PM   #24
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
Terry, stop it. You keep cheating! That's not a drilling time!
I want somebody to step up to the plate with an actual drilling time slower than mine!
Todd
Old 04-26-2008, 09:36 PM   #25
InsideOut's Avatar
1956 22' Safari
Images: 108
Maybe if it was a 1/4" stainless steel rivet
Shari
Old 04-26-2008, 09:48 PM   #26
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
rivet drilling pre-school
Hey, yall weren't all born rivet masters out there were you! Surely there are a few tales of slow drills from those good ole days in rivet pre-school?
Todd
Old 04-26-2008, 10:23 PM   #27
Well Preserved
1993 21' Sovereign
Well, there was that one time when the electric drill broke, and I had to hand-drill out several rivets with a dull bit...That took a while... Does that count?
Old 04-26-2008, 10:28 PM   #28
monocoque's Avatar
1975 29' Ambassador
San Antonio , Texas
hand-drilling stainless steel rivets
Hand-drilling and stainless steel rivets? Hey yall aren't being serious about this! I earned my 3 minutes the hard way!
Todd
Is this YOUR 15 minutes of fame calling? InsideOut Our Community 2 10-18-2007 10:26 AM
Dometic fix took 35 minutes :) Kistler Refrigerators 12 06-15-2007 06:21 PM
Using OnStar phone with Family Share minutes Airstream25 On The Road... 2 07-01-2006 08:32 AM
help!!! i just typed for 20 minutes and my post was lost vbob Airstream Motorhome Forums 4 03-02-2003 08:03 PM
