Old 08-13-2010, 04:57 PM   #1
mile2885's Avatar
1976 23' Safari
Milton , Washington
0.020 vs 0.025 2024 for belly pan
I just bought six 0.020" 2024 T3 in 4'x4' sheets for $29 and am planning on using i for the belly pan on my 76 Safari. After searching around I noticed that everybody is recommending 0.025". Does/will it make that big of difference? If it makes that big of a difference, i'll go with the thicker stuff. I thought it was a pretty good price but I might be wrong. Thanks in advance!
mile2885 is offline   Reply With Quote
Old 08-13-2010, 06:09 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
2024 is not particularly good for salt corrosion, which you may get from road salt or parking on the ocean front. The alloy has too much copper in it but does give you good strength. Widely used in airplanes prior to WWII but replaced by Alclad after problems during the war.
Old 08-13-2010, 06:09 PM   #3
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Are You Rich?
I like the price you paid. If the stuff does not dissolve in the rain, even better.
Too thick and it is very difficult to install.
Too thin and what it is flimsy?
If you fasten it without sags, holes and gaps you should be good to go.
At the factory the trailer was, before the coach put on, flipped over to take advantage of gravity. They used to do that, I do not know about current practices.
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Old 08-13-2010, 06:24 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My service manual shows that the belly pan is 3004 Aluminum 0.024". The 2024 T3 that you have is used on the skins. If you use these sheets you could polish the belly pan...
Richard
Old 08-13-2010, 08:10 PM   #5
mile2885's Avatar
1976 23' Safari
Milton , Washington
So it sounds like I'm better off finding the alclad based on corrosion. The size doesn't appear to be the issue.
Old 08-13-2010, 09:01 PM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Personally -- I wouldn't go with alclad for belly pan. And I've never heard this used for this purpose. I believe original specs were for 0.025".
Belly pan aluminum in vintage units certainly gets thinned from corrosion over time. So you are at least on even ground with so many other units out there. I'd use larger head rivets intended for belly pan and be happy with economical 0.020" that you've found -- Large Flange Rivets
5 meter Langford Nahanni
Old 08-14-2010, 04:50 AM   #7
toastie's Avatar
1955 22' Safari
Great Lake State , .
I used 0.040 5052, 5052 has the highest strength in the non-heatable alloys. 5052 aluminum sheet has higher fatigue strength than most alloys and has excellent corrosion resistance. Plus it was the only stuff the local dealer had in stock and with a good price. Very happy with the results.
toastie
ID:	108719   Click image for larger version
toastie is offline   Reply With Quote
Old 08-14-2010, 11:27 PM   #8
mile2885's Avatar
1976 23' Safari
Milton , Washington
Well, it can't be any worse than what I pulled off. I applied POR-15 to the frame and I'm planning on using what I have...I think I'll be fine.
Old 08-15-2010, 11:02 AM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
What you have should be fine, a little flimsy but just use more rivets. I, like Toastie also used .040 5052. I can get it local and it's cheaper then the 2024 with better corrosion resistance.
Old 08-15-2010, 12:12 PM   #10
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
alclad
Alclad is just 2024 alloy coated with pure aluminum for corrosion resistance. They also make 2024 sheets that are not alclad. Depends on what you have whether it's easily corroded or protected by the cladding. Look at the stamping on the back side of the sheets. It should tell you if it's alclad or not.
Old 09-10-2010, 04:07 AM   #11
RaleighAir's Avatar
1973 31' Sovereign
raleigh , North Carolina
I'm searching for exactly what to use for an antenna patch. Any advice on type/thickness of aluminum?
RaleighAir is offline   Reply With Quote
Old 09-10-2010, 07:06 AM   #12
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I just used whatever they had at Home Depot...they sell these 1 or 2' square pieces of alluminum; no idea of its specs, but for a small patch, I don't think it really matters much.
Toastie: what is that strip of aluminum that is wrapped around your grey tank? I was looking at your blog for tank inspiration, and noticed this in the pics, there, too...but there was no description of what it was, and what it was for.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 01-27-2011, 04:41 PM   #13
byron bay , NSW
is this thickness hard to work with for the belly pan i can get the 5052 in 0.032" thickness but i thought everyone used the 0.025" thickness the 0.025" is not available in my country, should i go with the 0.032".
clipperguy is offline   Reply With Quote
Old 01-27-2011, 06:44 PM   #14
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
I used .032 5052 for the belly wraps on my '55 Safari (because it was cheaper and easier to get) and found it best to pre-curve the edges by rolling them over a 6" dia. PVC pipe before trying to install them. With two of us pre-bending them this way we got it to hold the curve somewhat, but we had to hold it in place completing the bend with some force to get to the point we could rivet it in place. I've never worked with thinner stock, but assume it would be a little easier. But in the end, you can use .032 if necessary.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
aluminum, bellypan, material
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 21 08-29-2010 04:56 PM
Belly pan completely off......???? gutsgolf Belly Pans & Banana Wraps 33 10-28-2009 02:25 AM
Belly pan off or on ? augier Belly Pans & Banana Wraps 6 08-08-2009 02:04 PM
belly pan hlink Belly Pans & Banana Wraps 10 09-16-2008 07:51 AM
Water in the belly pan?!?!??? Safari Tim Leaks - Weatherstrips, Gaskets, Caulks & Sealants 22 04-28-2004 01:45 PM
