Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 09-16-2008, 09:58 AM   #15
thinking outside the box
Commercial Vendor
62overlander's Avatar
Profile:  1962 26' Overlander
1954 22' Safari
1954 22' Safari
Catonsville , Maryland
The key to the spray is fine overlapping strands of the glue. You want to create a web one both surfaces. Do not try to cover the surface as if you painting it on. It needs to dry 100% before you stick them together. That might be 1 minute it might be 10 all depends on the humidity. You can test by using the back of you hand... gently press your hand into the glue, if your hair sticks, wait. Do not rush the glue, for if it is not dry enough it will come apart later. Once the surfaces touch, that is it, so be lined up. A file will cut off the excess around the edge. Make sure to roll out the surface with a j bar roller. You can also wait too long and all the solvent will evaporate out of the glue and the bond will not take place.
62overlander is offline   Reply With Quote
Old 09-16-2008, 12:53 PM   #16
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
I have yet to find a 3M product that has not worked well. Thier glues work great! choose your stickyness and go for it.
We use thier glues for interiors.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 09-18-2008, 09:47 AM   #17
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Ok, well, the model-shop raid was a success!!
(turns out, we buy super-77 by the case. there was a half-can of "90" left; the model shop guys told me that they prefer the 77, but anyway...)
So, it seems to have worked nicely. It didn't soak in at all; just worked exactly as advertised.
So now I need to cut down one of the finished doors by a couple of inches. I'm thinking a jig saw with a fine-toothed blade would be the thing...masking tape on the laminate side, to deter any chipping. sound good?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-18-2008, 10:48 AM   #18
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Use masking tape, but cut with the door upside-down. Remember that most jigsaw blades cut on the pull stroke and tend to splinter on top. You can however buy "push" stroke blades.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 09-18-2008, 10:51 AM   #19
Fyrzowt's Avatar
Images: 8
Chuck,
On review, if you have access to a table saw or a circular saw you may get better results with a smoother/straighter cut.
If you wind up using a circular or jig saw, clamp a guide to the door so you can keep the saw on the mark.
Good luck.
Dave
AIR #15800
2000 Safari SS 25'
Old 09-18-2008, 11:50 AM   #20
Patriotic
Chuck's Avatar
Images: 99
no table saw. I do have a circular saw, and I was thinking of that + a plywood blade (fine-tooth). I'd have to cut it upside-down, though...might have to with either saw, as the width of the base plates is probably wider than the distance between the cut and the protruding metal handle of the door.
and yep, I have a clamp-on straight edge, just for such purposes.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 09-18-2008, 12:34 PM   #21
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
Jig saw may leave less ragged edge, unless you have a fine tooth blade in that saw....
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 01-09-2009, 09:55 AM   #22
Profile:  Currently Looking...
Cincinnati , Ohio
Chuck,
I have had a few jig saws in my time as a home remodeler and carpenter. I like using the Bosch jog saw more than any other that I have tried.
Matter of fact, I was home visiting Maw & Paw early last year, and had to do some work on their house. I pulled the Bosch out of the truck and cut a couple items for the new kitchen. (Contractor that they hired was a bit slow getting things done, and I just had to help out for a couple days.) I let Paw use the saw, and he instantly fell in love with it.
Paw wouldn't let me take the saw with me when I left, and it wasn't until Christmas that I was able to get my saw back. (Maw bought him one just like mine for a Christmas gift.)
I would use the jig saw, make sure you support the parts well. Possibly sandwich them in between two scrap boards. A slow feed-rate will be absolutely necessary. Use the finest toothed blade you can find.
Good luck,
Woody
Woody.303 is offline   Reply With Quote
Old 01-09-2009, 10:11 AM   #23
Commercial Vendor
Profile:  Corona , California
Also, cut the material, SLOOOOOOOOOOOOOOOOOOOOOOOOOOWLY, and the material will reward you.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-09-2009, 10:33 AM   #24
Patriotic
Chuck's Avatar
Images: 99
well, I used the jig saw and it didn't work out too well. had a couple of chip-outs...not a total disaster, as the damaged areas are hidden by the p-scrolls once installed. but next time, (I do have one more door to do), I'll use the rotozip.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 01-09-2009, 01:21 PM   #25
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Try using a metal cutting blade instead of a wood one. Also cut with the finished side of the tambour nest to the saw, but you probably already figured that one out.
Pay no attention to the man behind the curtain- WoZ
Old 01-09-2009, 02:37 PM   #26
VIKING's Avatar
Profile:  1964 22' Safari
Boulder Creek , California
A common problem with solvent based contact adhesives is humidity. The solvent evaporation causes moisture to form on the surfaces, and then they will not stick until the moisture has evaporated also.
The 3m-90 is a good all-around spray adhesive for permanent bonds. 3m-77 is not as strong, but it will allow you to re-position the two pieces if you need to.
If you ever see a can of brush-on green contact cement at a yardsale with the name "grip", BUY IT! It's the best stuff ever made for permanent bonds, and is no longer made due to the solvent content.
Good luck, Rich
VIKING is offline   Reply With Quote
Old 01-09-2009, 07:13 PM   #27
3 Dog Nite's Avatar
Profile:  1974 25' Tradewind
Cleveland , Tennessee
Tricks an old timer taught me
1) When cutting, Put down a pieces of masking tape on e cut line. Then remark the cut on the tape. This minimizes the "tear out" caused by the saw blade.
2) When making countertops, the contact cement will soak into the MDF (medium density fiberboard). Put 1st coat on the porous material only. Put the 2nd coat on porous material at same time that you coat the nonporous material. This way they are both tacky (dry to touch) at the same time.
3) If I have a countertop job coming up, I'll look through the curbside piles on trash night for an old venietian blind. The cheap plastic ones work best. Lay them down on the MDF board ( or your favorite porous material) about 1 " apart. Then you can place the formica (or your other material to be bonded) on top. You can the position it where it needs to be. It slides on the blinds. Once it's in place, you slowly pull out the blinds 1 at a time. Then roll out on top with a J-roller. This secures the bond. Remember you only get 1 chance if using quality contact cement. Make sure of the fit by putting items together 1st without cement. If possible oversize the material & trim later.
I know the voices in my head aren't real, but some of them have pretty good ideas.
AIR 22749
1974 25' Tradewind - no TV yet
1989 345 LE Classic Motorhome
Courtesy Parking; 20 amp, water, dump, wifi
'tween exits 27 & 33, I-75
3 Dog Nite is offline   Reply With Quote
Old 01-10-2009, 07:57 AM   #28
Commercial Vendor
1954 22' Safari
1954 22' Safari
a jig saw cuts on the up stroke... that causes chip out. Cut with the saw on the underside of the piece and it will not chip out. Also make sure the blade swing is set on zero.
Classifieds "Contact Seller" Link Not Working Barkingspider Forum How-To's & Support 10 05-14-2008 08:32 AM
Alum steel contact ? LI Pets Ribs, Skins & Rivets 14 09-17-2006 02:03 PM
search for contact frederic.c01 On The Road... 0 08-29-2006 02:13 PM
Brakesmart contact phone number Mike B Brakes & Brake Controllers 2 04-10-2006 11:56 AM
Outrigger wear to tire contact Johndigbydog Tires 10 01-20-2006 11:03 PM
