Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Prev Previous Post   Next Post Next
Old 11-25-2006, 11:27 AM   #1
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
Woodworkers - suggestions on finish.
The interior wood in the remodeled bed and bath in our 310 limited is cherry. The finish is a sprayed on lacquer. I'm in the process of adding/completing some trim work that wa never completed (It's a long story, alluded to elsewhere ). It been cold and damp here so spraying lacquer outdoors is not an option. Nor is spraying lacquer in the house - the only heated space available. I'm looking for suggestions for a finish which can be applied in the house which will match the existing finish.
Brush on lacquer, polyurethane, tung oil, watco?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Very rough finish lenny Cleaning, Stripping & Polishing 9 11-11-2002 06:42 PM
Fixing a scratch on a brushed finish? acwdgw Cleaning, Stripping & Polishing 3 10-22-2002 02:27 PM
Quebec campground suggestions rdm On The Road... 1 07-14-2002 05:34 AM
WD-40....will it harm the finish? Chuck Exterior Restoration Forum 1 07-05-2002 10:50 AM
Ideas, suggestions, needs? ALANSD Forum How-To's & Support 5 06-22-2002 10:21 PM
