Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
View Poll Results: What finish for that old-time 50's look?
Spar Varnish? 9 32.14%
Shellac? 6 21.43%
Tung Oil? 5 17.86%
Polyurethane? 4 14.29%
Other - please explain 4 14.29%
Voters: 28. You may not vote on this poll
Old 02-07-2009, 10:48 AM   #1
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Which finish on vintage wood?
The cabinets in our '64 GlobeTrotter were in great shape which necessitated minimal work. Not so with our '56 Safari cabinets which were painted and have been stripped down to the bare wood. They are birch - most are original, some new pieces and some new birch veneers over the original cabinets where the damage & staining was too great. I LOVE the old-time, high gloss, clear/amber finish in the '50s trailers but also want it to be maintenance free or low maintenance after we are done.
I am considering Spar Varnish, Shellac, Tung Oil and Poly-Urethane.
What should I use for an "original" look? Are there any I should absolutely stay away from in this application? Any others I should consider?
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Last edited by InsideOut; 02-07-2009 at 11:03 AM. Reason: added link & fixed typos
Old 02-07-2009, 11:02 AM   #2
Commercial Vendor
Profile:  Corona , California
Shari
Shari.
There are many types of furniture paints, and most have some sort of draw back.
We use a clear paint, or you can tint it if you wish, that is not harmed by UV, is water proof, takes a beating, and you can wax it if you wish.
Big secret? Nah.
Tons of gloss.
Ordinary high quality "automotive clear."
You can brush it or spray it, depending on how you thin it.
We have used it for years.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 02-07-2009, 12:01 PM   #3
1972 Travelux Princess 25
Profile:  Cobourg , Ontario
Spar varnish for the original "glow". This stuff will last for 50 years inside a trailer. Then give it another coat and it will be beautiful for another 50 years.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 02-07-2009, 12:05 PM   #4
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
When we redid our TradeWind, we used spar varnish and are very happy with the results. Its not extremely high gloss but it is shiny. Spar is used on boat interiors and exterior wood so we figured it would hold up to anything inside an Airstream.
Good luck with your decision.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is online now   Reply With Quote
Old 02-07-2009, 12:31 PM   #5
samb's Avatar
Profile:  1961 22' Safari
Union , Oregon
Images: 11
A trailer is just a landlocked boat so, from a builder of wooden boats-----Spar varnish.
Sam
samb is offline   Reply With Quote
Old 02-07-2009, 12:38 PM   #6
silverhawk's Avatar
Profile:  1964 22' Safari
Elyria , Ohio
Images: 20
Send a message via Yahoo to silverhawk
I used a Spar urethane finish in my 64. I do not know the difference from a spar varnish. I do know that is more water resistant, and has that UV protecting quality that you want in a trailer usage situation.
silverhawk is offline   Reply With Quote
Old 02-07-2009, 12:43 PM   #7
New Orleans , Louisiana
I have been using a product called crystalac for a few years. It is a waterborne finish. I am very happy with its ease of use and quality. I plan on using it for my cabinets when it comes time for finishing. They also have a marine grade varnish called Crabcote. Check out their website and see what you think. www.crystalac.com
valentine is offline   Reply With Quote
Old 02-07-2009, 01:45 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
I've got shellac on doors and millwork in my house. It's mighty fragile stuff and easy to mar. We're refinishing as we can and have to be very careful not to leave any lac residue -- it can cause hot spots (adhesion, bubbling) under alkyd varnishes.
I sure like Pratt & Lambert Varmor satin urethane. It's what you'd call oil based, so it's a little pricy for not being VOC compliant. Personally I don't know if I'd want the 'build' (thickness) of a spar varnish. Either spar varnishes or urethanes are as tough as they come though.
Old 02-07-2009, 01:58 PM   #9
Profile:  2002 19' Bambi
Lafayette , California
"Spar" varnishes are formulated to be UV resistant, which is not necessary for interior cabinets. Such varnishes are commonly yellower than oil-based varnishes for interior use. Almost all varnishes will yellow over time. Some of the water-based clear finishes do not yellow on their own, but the underlying wood may yellow with time to achieve the "look" you want.
For ease of application, some of the rub-on urethane or polyurethane finishes are hard to beat and they are capable of producing a very nice finish with several coats. Minwax and Rocklers both offer good rub-on products of this type and they produce a somewhat golden finish. The Rocklers finish produces a satiny gloss and Minwax offers both satin and gloss versions.
Tim A. is offline   Reply With Quote
Old 02-07-2009, 02:29 PM   #10
Profile:  1963 24' Tradewind
San Diego , California
The spar varnish has an amber tone to it and it will change the color of the stain,may yellow, darken the wood color etc. also it is an oil base coating that requires paint thinner to clean up, it can be a little messy and sticky. Being an oil base it takes longer to dry and extra long in areas with high humidity. The newer water borne clear coats are great. They will not yellow, change the color of the stain or wood. Works well in all climates, multi coats can be applied in a short time, sands easy, easy clean up etc. Home Depot has a few to chose from Fletco Varethane Diamond Finish in different sheens satin, semi gloss, gloss. I like the satin finish it looks hand rubbed
and easy to touch up. Good Luck
I voted other "Water Borne Clear Coats"
Sixty3TW4US is offline   Reply With Quote
Old 02-07-2009, 02:43 PM   #11
InsideOut's Avatar
1956 22' Safari
Images: 87
My thoughts so far...
  • Wouldn't the UV protection of Spar Varnish be a good thing in a trailer with as many windows as we have?
  • We are most likely NOT going to stain the wood first - we like the light birch - and it's most like the original
  • I don't mind yellowing or the amber cast - adds character & looks vintage IMO
  • We want a gloss to high-gloss finish like a boat interior
  • LOVE the look of Shellac - but we're feeling it's not right because of it's fragility and incompatibility with water
  • I guess we are leaning towards the Spar Varnish but the idea of 4+ coats with 48 hours between coats is a bit overwhelming - we do have day jobs :grin:
Keep your thoughts & suggestions coming in...I don't have to make a decision today - still lots of prep-work & re-veneering to do ~
Shari
Old 02-07-2009, 03:19 PM   #12
Aluminum in 3-D
Blue Pearl's Avatar
Profile:  1981 27' Excella II
1968 28' Ambassador
Seaside , Oregon
I guess I'm the only Shellac lover here, but that is what I put on all my 81 excella cabinets and even the table, I have venered all cabinets with bamboo then shellac 2 or 3 coats (like 10 min between coats) then I sealed with a water based poly. Holding up well and the reason I used the shallac is the color it gives the cabinets. On the 68 Ambassador I'm just using a low sheen polyurathane or varnish to give the waxed look for the walnut walls.
Name:	hd damage 092.jpg
Teresa
wbcci#8209
Air Forum#17236
Aluminum in 3-D
Blue Pearl is offline   Reply With Quote
Old 02-07-2009, 03:21 PM   #13
Road Trip ! May I suggest that you go to Home Depot or ? and pick up a good size piece of wood similar to the wood in your AS, then a small can each of the finishes you are considering and do sample boards. That way you can see the finish and workability of each coating. It shouldn't cost to much. Don't rule out the new water borne clear coats until you give them a try, gloss finish re-coat in 45 min. When applying an oil base Spar Varnish do not apply it to thick, it will skim over before it dries and the solvents will not evaporate and the finish will wrinkle, thin coats are best. Again Good Luck
Old 02-07-2009, 03:24 PM   #14
Blue Pearl, They do look GOOD!!
Vintage Tow Vehicle - Vintage Argosy Adventure to Bozeman overlander64 Off Topic Forum 16 07-16-2008 05:15 PM
Name that finish! Stefrobrts Upholstery, Blinds, Walls & Interior Finishes 3 05-28-2004 12:55 AM
New AS finish vs vintage Safari Tim Our Community 7 09-19-2003 10:42 AM
Original Finish Bfrank Airstream Motorhome Forums 5 08-11-2003 07:57 PM
92 MH-Ext Finish CBBOB Airstream Motorhome Forums 1 09-26-2002 07:37 PM
