Old 05-30-2011, 02:18 PM   #1
kljfamily's Avatar
1975 25' Tradewind
albuqerque , New Mexico
Where to get aluminum extrusions for walls
Hi as you can see from the picute I have no furniture from the entrace door all the way to the single bed on the left. I need to put up the walls and rebuild the surround for the fridge and I think what is another closet to the right of that. The fridge is a rm77. so it is tall,.. I know my way aournd a saw and can fabricate new walls but how to mount the walls to the shell is another matter. I have 1 auminum extrustion that was found in a closet. DO they still make these and if not how should I go about making new wall attached to the shell?
to sum up
are the aluminum guides that attach to the walls stillavailalbe,,,if not what can i use instead?
I have 2 rails seen in the picutre already...they look as though they will fit a 1/4 inch thick material. What type of material do you suggest?
Also, what type of hooks are used in the shower for the cutrtain I attached a pic of that as well.
1975 tradwind 25 footer
ID:	131112   Click image for larger version
kljfamily is offline   Reply With Quote
Old 05-30-2011, 04:36 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If yu can't find the material through one of the RV Supply distributers, many in the Elkhart Ind area you may look to an architectural supply house that specializes in metal extrusions. Another area to check would be glass shops as metal edging is common there also.
2004 Excursion 4x4
Old 06-01-2011, 06:42 AM   #3
1973 25' Tradewind
1964 19' Globetrotter
Centerville , Utah
Vintagetrailersupply.com under Interior/Moulding and trim.
tclay
Stormy Weather is offline   Reply With Quote
Old 06-01-2011, 07:23 AM   #4
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
outwater plastics also has them
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 06-01-2011, 10:31 AM   #5
kljfamily's Avatar
1975 25' Tradewind
thanks I'll try both!
Old 06-02-2011, 10:13 AM   #6
kljfamily's Avatar
1975 25' Tradewind
Vintagetrailersupply.com had everything I needed I appreciate the heads up
Old 06-02-2011, 11:26 AM   #7
1973 25' Tradewind
Centerville , Utah
Awesome! Good luck with the project!
tclay
Old 06-15-2011, 12:39 AM   #8
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Some of my wall mounts had clips in them too. They clipped to the edge of the wall material and then inserted into the channel.
Phrunes is offline   Reply With Quote
Old 10-18-2017, 01:32 PM   #9
1976 31' Sovereign
Helotes , Texas
Aluminum extrusions
I just finished gutting a '76 31' Sovereign. Some of my alum. extrusion pieces were bent in the process, but I did try to take care for most. I was just about to start the process of separating all of the aluminum from the plywood and plastic, so I do not know what I have. I know I have the piece you are looking for because I saved it to use as a template for the wall curvature. It is anodized in a light bronze color, but I suspect you could paint it. It may take me a few days to sort through everything I have that is re-useable.
glrtex is offline   Reply With Quote
Old 11-09-2017, 01:19 PM   #10
1976 29' Ambassador
Dallas , Texas
You can get them from here.
http://www.brunnerent.com/Tools/Port...=8&strMetaTag=
I just ordered some.
tabney0315 is offline   Reply With Quote
Aluminum desk top worksology Cabinets, Counter Tops & Furnishings 33 06-30-2011 05:47 AM
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 08:08 PM
Coated Aluminum glh101282 Clearcoat, Exterior Paint & Trim 6 02-24-2011 10:38 PM
Aluminum Water Hose Al - K4GLU Fresh Water Systems 14 02-05-2011 05:47 AM
