Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 09-09-2009, 06:18 PM   #1
Profile:  1980 24' Caravelle
1980 24' Caravelle
1959 24' Tradewind
woking , surrey
where to find aluminium tabletop edge trim?
My 1980 caravelles have rubber t profile edge protectors on table top but also other panels. The have started to part etc and I'd like to replace them with the typical aluminium trim I see on so many table edges in 50'and 60's trailers. Not sure if it was standard then or retrofitted, but either way I'd be interested to find a source for this trim.
thx
wiebe
turfclubroad is offline   Reply With Quote
Old 09-09-2009, 06:25 PM   #2
Profile:  1960 24' Tradewind
Riverside , California
Try here:
McMaster-Carr of course now the rest of your life will be devoted to looking thru their catalog.
Greg
ZoomZoom is offline   Reply With Quote
Old 09-09-2009, 06:57 PM   #3
Profile:  1972 25' Tradewind
Mobile By Way Of Atlanta, By Way Of Denver! , Alabama
check with www.vintagetrailersupply.com too... I remember this time last they had two different types of aluminum countertop edge moulding...
Good luck..
Shar
72BamaStream is offline   Reply With Quote
Old 09-09-2009, 07:03 PM   #4
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
Also check Ace Hardware...that's where we got ours...
Also check this thread: aluminum counter trim
Good luck!
TB & Greg...and Cockers Annie & Sadie
AirForums #21900 . WBCCI F
our Corners Unit #3954
Décor Site: AZBambi Décors
Old 09-10-2009, 12:00 PM   #5
dnrtheil's Avatar
Profile:  1964 24' Tradewind
Portage , Michigan
What I used was 3/4" wide aluminum trim designed to be used with carpeting. I bought everything both of my local Menards had, I have also seen it at our local hardware store. Go to the carpet area.
Derek
Name:	Counter top trim.jpg
Operation "SAVE RUDY" Strike Team (Associate Member)
dnrtheil is offline   Reply With Quote
Old 09-10-2009, 03:17 PM   #6
1980 24' Caravelle
1959 24' Tradewind
woking , surrey
Aluminum and Stainless Steel Tee Nosings
for instance...
do I love thios forum pr not? Dont think it would be possible to own an older airstream in Europe without access to this forum.
thx!!
WIebe
Old 09-20-2009, 10:45 AM   #7
Profile:  1965 17' Caravel
SAN LUIS OBISPO , California
Source for aluminum t-moulding
thanks go to member InsideOut , I was just viewing their dinette information and came across their link to this supplier and confirmed they have what you and I are both looking for.
TAPE-EASE: WOOD VENEER EDGEBANDING & WOOD SHEET VENEER, PVC, CURVED PLYWOOD & Much More
SSTANK05 is offline   Reply With Quote
Old 09-20-2009, 12:34 PM   #8
georgezink's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Lawrenceville , Georgia
You might try Outwater Plastics Industries, 24 River Road, Bogota, NJ 07603 201-498-8750. We bought our aluminum trim from them and they provided good service. Not sure if they have exactly what you are looking for, but they are worth a look.
flcracker
georgezink is offline   Reply With Quote
Bronze Edge Metal Trim 72 Tradewind RichHog General Interior Topics 8 09-23-2009 06:35 PM
Help on plastic edge trim inserts Idaho Ken Upholstery, Blinds, Walls & Interior Finishes 8 11-11-2007 02:17 PM
Attaching and Bending Edge Trim PhilMateo Cabinets, Counter Tops & Furnishings 1 03-27-2006 08:56 AM
seal the bottom edge trim pieces? cindy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 10-23-2002 10:18 AM
Interior Trim-Where to find it???? 74Tradewind Upholstery, Blinds, Walls & Interior Finishes 1 07-05-2002 11:12 PM
