Old 01-23-2013, 02:38 PM   #15
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
The hinges are very delicate for the weight of the doors on my 81 Excella. They are 3/4 MDF and are heavy. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 01-23-2013, 03:17 PM   #16
Originally Posted by lewishw View Post
Andy,
Have they made these hinges stronger than they used to be? Im torn between replacing the originals, or just buying some piano hinges that will surely be strong enough.
What do you think?
Hunter
The original hinges are fine.
But, they can be destroyed when owners do not do the PM's that are necessary.
The following list is what causes the hinges to break.
1. Bad rubber rods in the axles.
2. Improper or no running gear balance.
3. Excessive rated hitch bars.
4. Excessive rated tow vehicles.
May, many owners are still using the same hinges, without any problems.
Vibration, can destroy most anything.
Installing heavier duty hinges only delays the issue of ridding the coach of any and all vibrations.
Most solutions are based on what was the cause of the problem.
I would suggest that you address the vibration issues.
And certainly, a cabinet door flying open and closed for a trip, would most likely destroy most hinges.
The other issue of using piano hinges, is simple looks.
But, the bottom line is always up to the owner.
Old 01-23-2013, 08:39 PM   #17
1993 36' Land Yacht
jackson , Tennessee
Google Colaws in Joplin, MO. if they dont have anything you need that means it doesn't exist anymore. True miracle workers.
bukib is offline   Reply With Quote
Old 01-23-2013, 08:41 PM   #18
The original hinge is still available.
Old 10-07-2014, 08:36 AM   #19
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Springfield , Missouri
Images: 125
hinges for closet door.
Originally Posted by Inland RV Center, In View Post
Is this what your looking for?
http://www.inlandrv.com/catalog/imag...osethinges.jpg
Just got back from 4 month tour of the NW..... new axles, brakes tires etc, performed as expected. Only problem was hubcaps shearing off valve stems. Am replacing them all with metal valve stems.
On the trip home from Moab, I had hung a towel over the closet door of our 31' 1978 Sovereign and didn't shut the door completely.
I-70 is rough! and bouncy.... broke the hinge... Andy, do you still have these hinges?
Thanks> btw, now that I am back, I will be shipping those shocks back to you.
Jim Lee is offline   Reply With Quote
80 airstream cabinet hinges bluegoat80 Cabinets, Counter Tops & Furnishings 3 01-29-2010 10:39 AM
New cabinet doors and hinges seventythree Cabinets, Counter Tops & Furnishings 12 12-17-2009 10:05 AM
80 airstream cabinet hinges bluegoat80 Cabinets, Counter Tops & Furnishings 5 12-02-2009 07:25 AM
replacing CABINET/storage door hinges. bookman Cabinets, Counter Tops & Furnishings 5 08-04-2008 11:23 AM
Door hinges & new screen door? JKWoodrow Doors & Locks 5 11-17-2006 09:39 AM
