Old 10-03-2017, 06:39 PM   #1
Arlington , Texas
What's behind door #1
I cannot figure out if this is actually a door. It has a knob and hinges at the bottom but it doesn't want to open. I have tugged on it almost to the point of breaking something. It is in the bathroom of a 2003 Classic 25' I just purchased. Any ideas what is going on?
Rbarlow is offline   Reply With Quote
Old 10-03-2017, 06:41 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by Rbarlow View Post
Attachment 296156
Looks like access to the rear of the water heater.
Old 10-03-2017, 06:48 PM   #3
2000 25' Safari
Denver , North Carolina
I had a door like that but it ended up being velcroed. I was sure I was breaking something. I just stared at the corner and worked it down and off. Maybe obvious, have you searched from the otherside / outside?
mbubbaca is online now   Reply With Quote
Old 10-03-2017, 07:21 PM   #4
Arlington , Texas
The water heater is further to the rear. I believe the wheel well is behind it.
It doesn't even look like a door. The sides seem sealed. It's just weird that it has hinges and a knob.
Old 10-03-2017, 07:28 PM   #5
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Looks to me like it is intended to open in??? Did you push in?
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 10-03-2017, 07:33 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
My trailer has one like it. The fender well is behind it. You can get to some plumbing through it. I don't want store anything hard in there that might damage the wiring or plumbing. I put toilet paper and paper towels in it.....it just pulls open.
CRH is offline   Reply With Quote
Old 10-04-2017, 09:38 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
That's what I was thinking...
Maybe it is access to the water heater bypass or some plumbing or wiring or all of the above...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-04-2017, 11:05 AM   #8
1996 25' Excella
Tillsonburg , Ontario
Yes it covers the fender well and some piping
I use it to store my tank treatments and spare water pump. Stuff does fall forward of the wheel well and is difficult to retrieve
The door is hinged on the bottom and is typically very difficult to open since the catch is seldom operated... "pull Hard"
JCW
JCWDCW is offline   Reply With Quote
Old 10-04-2017, 11:08 AM   #9
m.hony's Avatar
2013 30' Classic
Try wiggling up and down and left and right while pulling...
TAC #MS-10
Airforums #70955
Old 10-04-2017, 11:32 AM   #10
RJJ
RJJ's Avatar
2016 26' Flying Cloud
2016 20' Flying Cloud
St Petersburg , Florida
Does the know turn at all?? Might need to run a blunt blade or credit card around the edge to loosen the seal.
RJJ is offline   Reply With Quote
Old 10-04-2017, 04:49 PM   #11
MySovereign's Avatar
1976 31' Sovereign
Cleveland , Oklahoma
Hmmm.
The door or your body?
MySovereign is offline   Reply With Quote
Old 10-04-2017, 05:11 PM   #12
Arlington , Texas
I pulled as hard as I am comfortable doing. Something Is fixing to break. Since the reward is possibly only a very small area behind the door, I am not going to risk tearing it up.
Old 10-04-2017, 05:46 PM   #13
1972 25' Tradewind
Detroit , Michigan
Even if no one else did, I saw what you did there! Funny!
TR Anderson is offline   Reply With Quote
Old 12-07-2017, 11:41 PM   #14
Thunder Bay , Ontario
If you zoom in it looks like there's screws driven in from above down into the door on either side of the knob...
Richie1983 is offline   Reply With Quote
slow drip behind outside water heater door iHayley Water Heaters, Filters & Pumps 12 04-30-2009 06:10 PM
What's behind door number 3? PuddlePyrate All Argosy Trailers 17 10-07-2008 06:38 PM
What's behind Door #1? (pic needed) 59 GlobTro 1966 - 1968 Safari 4 07-25-2008 09:38 PM
What was behind this door? lebolewis Electrical - Systems, Generators, Batteries & Solar 4 06-18-2006 06:21 PM
Side door behind the axle jcanavera Airstream Trailer Forums 3 02-28-2003 11:03 AM
