Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 01-07-2005, 05:37 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
What wood would you use?
I am trying to spec the wood out for my dinette table and seats.
I plan on using 3/4" material for the table top doubling up on the eding so I have something to work with. I want to put metal edging on it if I can find some. I plan on laminating is so the material does not have to be of finish quality.
A half sheet of 3/4" plywood is around $25 and a full sheet of OSB was arond $12 or $16 (can't remember).
What kind should I be using? I want more bang for my buck but not at the risk of ending up with something of poor quality.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 01-07-2005, 05:59 PM   #2
sovereignrwe's Avatar
Profile:  1972 31' Sovereign
Oakdale , Minnesota
Weight might also be a consideration. Are you trying to match the original laminate?
I will be interested in the upcoming posts. I will try to repair the table ledge this spring. I will try gorilla glue first, then replace if need be. Our previous owners left a veneer sample in the trailer. I don't know if it is still made, but I have a maker, color, and number to search on.
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 01-07-2005, 06:03 PM   #3
Profile:  , Minnesota
Images: 59
I would not use OSB, which is intended for wall sheathing or subfloor. A better material is MDF.
http://www.design-technology.org/mdf.htm
Old 01-07-2005, 06:07 PM   #4
Profile:
Plywood is much stronger than OSB size for size. And certainly much lighter. For a table top, you have more finishing options with finish grade plywood.
3/4" plywood is not actually necessary. With some minimal framing you can use 1/2" for the dinette seats, or 3/8" with a bit more. My "double" bed has a 3/8" plywood platform.
Mark
Old 01-07-2005, 06:33 PM   #5
Profile:  1994 30' Excella
Mississauga , Ontario
earlier post mentioned MDF. This is very heavy! Veneer core sheeting is much stronger than particle board. Plywood sometimes has a warp in it so I would be careful to make sure the piece you use is flat from the start. A table top isn't really fastened to anything that will restrain it from warping. If you apply a plastic laminate to the top surface of the table top it is probably a good idea to do the same on the bottom to prevent a warp.
Old 01-07-2005, 07:08 PM   #6
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
If I were making one for my unit it would be red oak ply with red oak solid for the edges, because my trailer is all oak inside. My table is oak trim with a laminate oak top. It doesn't look bad but its not as pretty as the newer tables that are not laminate. The birch plywood is very reasonable in price and the grain is so much tighter. It makes a nice table top as well. Wood has all of the upkeep problems but looks great, laminate looks good and has fewer upkeep issues.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 01-07-2005, 07:27 PM   #7
Safari Tim's Avatar
Images: 35
I went back and browsed the wood isle again. I saw thay had a full sheet of 3/4" birch laminate for $33.
That would be the way to go if I just go ahead and stain it and put some sort of polyurethane on it.
I cannot find any metal edging there (Home Depot) anyway. So I could just put some kind of wood edging on it with some glue and pin nails.
Whatever I do it has to support some weight when it's converted to a bed.
Argh... to many decisions.
Someone just tell me what to do
-Tim
Old 01-07-2005, 07:43 PM   #8
'97 Excella 25
Bob Thompson's Avatar
Profile:  Corpus Christi , Texas
Images: 60
There's a big difference between various plywoods. I've seen 9-ply Baltic Birch warp big time and it is supposed to be amoung the best for strength and stability. If it were me, I would try to use lumber core plywood. Lumber core plywood is often used for library shelving so it should be good for table tops assuming you are going to band the edge. Lumber core plywood should be available at your local specialty woods supplier.
Bob Thompson is offline   Reply With Quote
Old 01-07-2005, 07:48 PM   #9
Old Paint, rolling again.
sfixx's Avatar
Profile:  1973 Argosy 20
Lorain County , Ohio
Images: 13
Send a message via AIM to sfixx
Tim's Dinette Project
Hi Tim,
I'm in the market for a dinette too but haven't really gotten into construction details yet. First here's a very handy link for table edging. Outwater Plastics will send you a HUGE free catalog. Check out "extrusions" section for edging.
http://www.outwater.com/outwater.html
Of course your table top needs to be very strong because it supports the middle of what is potentially a 2 person bed not to mention any gymnastics the kids may perform on it. I think that 3/4" birch plywood with doubled edges and probably an 3-4" wide rib running down the middle would be best. You already said that you prefere lamainate, and I do too for it's durability. If you don't laminate the underside at least seal it with varnish or polyurethane. That keeps the humidity from affecting just one side and causing the top to warp.
If your bench seats are going to be painted or stained 1/2" birch ply will give you a nice surface to finish and it will match your cabinets, but if you're going to fabric cover them (like I'm thinking) a lesser grade of plywood will do. I bet the total weight saving of using 1/2" instead of 3/4" plywood throughout would be less that 30 lbs but that weight is as far towards the tongue as possible thus multiplying it's ill affect. You could actually use 1/4" ply on the sides if all the strength is in your framing.
BTW, do you have a water tank under the front bed? What are you doing about that?
I'll be interested in your progress. Please keep us posted.
Steve
Have you never questioned those who travel?
Have you paid no regard to their accounts- Job 21:29
Fixxer's Argosy Resto-Blog
Courtesy Parking: 15 minutes off the Ohio Turnpike West of Cleveland... W/30 amp/water+WIFI ...The Next Best Thing to Larry and Lou's TM
sfixx is offline   Reply With Quote
Old 01-07-2005, 08:12 PM   #10
Safari Tim's Avatar
Images: 35
Thanks Steve,
That's really what I want to do. Because if I can figure out how to laminate, I want to redo the kitchen counters as well.
I already ordered the outwater catalog....
-Tim
Old 01-07-2005, 08:36 PM   #11
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
I used 3/4" for the table top with a 13/16" extruded aluminum t-moulding from Outwater Plastics, no doubling up on the edge or extra supports. On ours, the tabletop is small (30"w X 36"l) and is supported along both 36" lengths by the bench seat and a table leg in the middle of the front edge - 6-9" or so. And in the table position along the wall just below the window.
The dinette benches are made with 1/4" verticals and 3/8" seating platforms. If I were to do it over again, I would use 1/4" on the seats too, as there is plenty of support from the framework below....the maximum span is only about 18".
I have posted lots of pictures in my gallery and on our website to show what I did. Even though ours has 'vintage styling' the pictures may help ~
Good luck with your project!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 01-07-2005, 08:42 PM   #12
Safari Tim's Avatar
Images: 35
Thanks for the info Shari. Your table looks great.
Was it hard to route the groove for the t-moulding? Any tips?
I like what you did with the fabric for the front and sides as well....
How thick is the padding that goes over the table when you make it into a bed? Is it comfortable?
My wife liked the bed the way it was, so I have to make sure the one I make is at least as nice!
-Tim
Old 01-07-2005, 08:47 PM   #13
sfixx's Avatar
Images: 13
Personally I like new tasks that require me to self teach a skill and buy new tools but if you're not set up to router I'm sure that a local cabinet shop wouldn't charge too much just to stick on and trim one piece of Formica, especially if you've prepared it before hand. That's a good option also if you can't work outside this time of the year.
If you have a router the only other thing you need is a "flush trim bit" to trim the laminate to size once it's stuck to the table top. If you're only doing the top and not the edges it should be a breeze to learn the process on this project. I'd be glad to talk you through it but you've probably seen Norm and Bob Villa do it dozens of times.
Steve
Old 01-07-2005, 08:55 PM   #14
Safari Tim's Avatar
Images: 35
Thanks Steve,
I've read over and over the sites on how to, so I think I have a good grasp of it.
Unfortunatly I don't have the tools and I would invest im them, but for me this would be a one shot deal.
However, my cousin has a complete woodshop full of neat stuff. He is just too busy
So, I should be able to borrow what I need.
While waiting for good weather, I'm making a good plan.
I'm one of those guys who digs way too deep into stuff like this and actually see the work done in my head over and over way before I pick up a tool
-Tim
wood walls in an A/S? Dave Cole Upholstery, Blinds, Walls & Interior Finishes 26 03-10-2008 12:35 PM
year wood veneer changed to laminate? thx yukonsilver Interior Restoration Forum 4 04-18-2004 06:31 PM
Wood veneer type Silver Bullet Cabinets, Counter Tops & Furnishings 7 03-25-2004 07:46 PM
Interior refinishing wood panels Excella3287 Cabinets, Counter Tops & Furnishings 7 04-29-2003 01:07 AM
wood endcaps inside? Dave Cole Upholstery, Blinds, Walls & Interior Finishes 1 11-01-2002 03:32 PM
