03-18-2010, 01:27 PM
#41
Islay - 63 O.
Montreal
images or link to them to see how it looks like... thanks
Originally Posted by boatdoc
Hi Hampstead;
My interior is all new African OKUME [Mahogany] plywood. Overlander has given you an excellent tip on framing. Spruce is very light and strong, it takes glue very well.
As for the floor, it is not my intention to argue with guy's who want nyloboard. I have not tested that material for expansion/contraction and softening in high heat.
I do know one thing if it says "NYLON" it is affected by temperatures unless some other component is added to stabilize it. It can also be heavy because there is no lightweight nylon.
My floor is 1/2" aluminum clad both sides plywood. It is void less and glued with waterproof glue. Most of all it has the rigidity of 3/4" exterior ply because of aluminum skin on both sides. Tho seal the edges I have used 1/2" aluminum C channel from McMaster-Carr. That trim is 1/2" wide on top and 1.1/4" leg on the bottom. To make the round corners I have cut V shape notches in the 1.1/4" underside part of the trim. The 1/2" top has no problem accepting the radius. The outside C trim was filled to 1/8" thick layer of 3M 5200 adhesive. Holes were pre-drilled and countersunk for #6 SS flat head screws into the edge of ply horizontally. The trim was tapped on with plastic hammer over a piece of scrap wood not to distort the trim. Excess adhesive was cleaned up. The joints in H trim were also treated with 3M 5200. All fasteners to frame were pre-drilled with 3/16 drill into the frame. Holes in ply were opened up to 1/4". All screw holes were treated with 5200 but not countersunk. This allow the flat head 1/4x 20 SS screws to compress the top skin of the ply thus making them watertight. The 5200 also serves as form of locking component for the 1/4X20 screws. The joints between the individual sheets were joined via horizontally laid H trim. All trim is 1/16" in thickness. It needs to be said here that 3M 5200 makes a forever seal. Thanks "Boatdoc"
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
https://rvcampreview.com
03-18-2010, 10:37 PM
#42
1967 26' Overlander
Owings Mills
, MD
There's no shortage of beautiful woods... and the craftsman to do them justice. I'm just not talented enough to ultra high end materials.
03-19-2010, 04:19 AM
#43
Baltimore
, Maryland
You are way too hard on yourself. 90% of wood working is confidence.
06-24-2010, 04:01 PM
#44
1970 23' Safari
Ventura
In reply to argosy brian, how did you use bamboo for the walls? Pictures?
06-24-2010, 05:23 PM
#45
2007 25' Classic
Hydes
Good sharp tools and skill helps.
06-29-2010, 05:26 PM
#46
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Mahogany?
We are getting ready to make a decision on what wood to use for overhead cabinets and matching floor cabinets. Anyone have some pictures of cabinets they built using mahogany? If you used mahogany, did you stain or leave it natural? Thanks for your help!
TAC PA-5
07-20-2010, 05:32 PM
#47
Burkie
1965 24' Tradewind
1983 34' Excella
1951 21' Flying Cloud
Lodi
We bought a '65 TradeWind. The owner removed all the cabinetry to strip it because a previous owner had painted everything blue. Now, one of the MAIN reasons I bought the trailer was because of the beautiful mahogany woodwork used in that year of manufacture. Unfortunately, I've stripped the paint off a couple of the cabinet doors only to find out that somebody replaced them with cheap plywood at some point.
Anyone know where to find cabinet parts for Airstreams? Or a good source for mahogany board?
06-20-2011, 11:50 PM
#48
1970 31' Sovereign
Tecumseh
, Kansas
In replacing yucky a couple looking interior walls, what would be appropriate thickness and strength. We planned on refinishing what we can save but just need to replace a few pieces here and there that are not in very good condition.
Thanks for any advice!
Candice
06-22-2011, 04:56 AM
#49
Silver Mist
Riverhead
, New York
you can use 1/4" for most, depends on what you're replacing
