Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 12-12-2016, 11:46 AM   #1
1978 31' Sovereign
Botgek , Washington
what type of wood did you use?
I've been double guessing the type of wood that the lumber yard recommended to use in our renovation. Looking for what others have used.
I have 1/2" ACX shop grade plywood for the walls/partitions. I've sanded and painted them and it's not a smooth as I was hoping for (grit: 120, 220, 320). I haven't found much information about the type of wood others are using for walls and cabinents, any tips would be greatly appreciated. As for face frame wood, I will be using 3/4" poplar.
Thanks!
Ryan
https://www.instagram.com/mcstreamytheairstream/
Sirwalshalot is offline   Reply With Quote
Old 12-12-2016, 11:55 AM   #2
Journeyman
2016 25' International
Amherst , Massachusetts
There is such a thing as cabinet grade plywood, but you won't find it at Home Depot or any big box stores. Comes in many different finishes ranging from white melamine (great for inside cupboards) to exotic wood.
I believe the new Airstreams use a product called "Lightply" and then they veneer/laminate over it.
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 12-12-2016, 12:10 PM   #3
jay
1974 27' Overlander
danville , New Hampshire
I used 1/4" Baltic Birch for my partitions. Took the clear poly perfectly and stronger than regular ply. It was hard to find. Had to go to a specialty shop. Poplar is nice for anything painted and it is light and strong so I used it for my inside frames. I used a mixture of Birch with Oak trim for my face frames and with the clear poly there is a nice contrast.
jaygood31 is offline   Reply With Quote
Old 12-12-2016, 12:30 PM   #4
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Check large lumber suppliers in your area who carry a wide variety of sheet goods. Ask for cabinet grade, 'birch' faced ply or be prepared to veneer ACX grade.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 12-12-2016, 01:18 PM   #5
1978 31' Sovereign
Botgek , Washington
It's all getting painted white, not sure what the veneer will add unless it is for texture?
I've been getting most of it at Dunn lumber which has a good selection and quality for the most part. I get various suggestions there and there are so many options and a range of prices.
So ACX is not a good choice?
THanks,
Ryan
Old 12-12-2016, 02:28 PM   #6
2002 19' Bambi
Lafayette , California
If your want a smooth white finish with your ACX plywood, you will probably be doing quite a bit more sanding during the priming and painting process. If they use plywood, many cabinetmakers chose a type with a smooth veneer surface (birch, for example) for painted cabinets in order to achieve a good smooth finish.
Tim
Tim A. is offline   Reply With Quote
Old 12-12-2016, 02:30 PM   #7
2021 16' Bambi
2021 22' Bambi
North Port , Florida
Since you are just painting the walls I would start with something around 60/80 grit and see if you can smooth it out enough to your liking. If not I would start looking at hardwood plywood. Generally the Chinese hardwood is about 1/2 the price of US ply, but since your painting it wouldn't matter but will be smooth from the start.
Poplar is a good choice for your face frames (since your are painting) Light and strong
cliffcharb is offline   Reply With Quote
Old 12-12-2016, 02:59 PM   #8
2010 25' FB Flying Cloud
Davenport , Iowa
I tried to make a butcher block table, and one section could not be sanded. When i primed it, it would raise the grain but the rest of the wood sanded and primed fine. I tried to cover with special SW paint but to no good; $25/qt. yes
I gave up and purchased Birch plywood furniture grade at Menards, did fine.
Airtandem is offline   Reply With Quote
Old 12-13-2016, 11:59 AM   #9
Rgentum's Avatar
2016 27' Flying Cloud
Olympia , Washington
What you need is furniture grade plywood or, better, marine grade plywood. In Washington, the two main suppliers are:
crosscuthardwoods.com and edensaw.com
Take a look at the sheetgoods at those websites, & you should be able to find what you want, although at a price significantly greater than construction plywood at Home Depot.
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
Rgentum is offline   Reply With Quote
Old 12-13-2016, 02:31 PM   #10
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I'm new to cabinetry but I am doing a facing on my galley with cabinet doors to replace the tambour I have repaired one time too many. I am using Alder.
Old 12-13-2016, 04:49 PM   #11
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Your city on your account through me, you mean: Bothell.
You are looking for paint grade plywood. Surprisingly paint grade is more difficult to produce on wood, as you found. Likely a better primer would solve your problem. I would switch to a high build sand-able primer.
Steve
sgschwend is offline   Reply With Quote
Old 12-13-2016, 05:17 PM   #12
2015 25' FB Flying Cloud
Kenmore , Washington
Fir is also tough to make smother via sanding. Unless you use a very hard and flat sanding block, the soft grain is removed faster than the harder areas of grain. This accentuates the grain pattern you are trying to hide. Sanding between coats of a high build primer is a good suggestion.
MitchR55 is offline   Reply With Quote
Old 12-13-2016, 08:10 PM   #13
2002 19' Bambi
Originally Posted by sgschwend View Post
Your city on your account threw me, you mean: Bothell.
Steve
And shouldn't yours be Oak Harbor rather than Oak Habor. Then again, perhaps you have a Boston accent!
Tim
What type of wood to use? LI Pets Cabinets, Counter Tops & Furnishings 48 06-22-2011 04:56 AM
What type of wood should I use in my 1956 AS Dan Clayton General Interior Topics 6 12-24-2009 12:28 AM
What brand / type of grease do you use? JDL Axles 10 07-30-2007 05:48 PM
What type of tow vehicle do you use? John Community Polls 24 08-07-2005 08:37 PM
What wood would you use? Safari Tim Cabinets, Counter Tops & Furnishings 71 02-18-2005 01:36 PM
