Replace or Rebuild
If the countertop and galley cabinet are damaged beyond a minor repair then you may want to replace it all. If the countertop has the damage it could be stripped of the formica (with a heat gun) and replacement material installed on the existing countertop plywood. If the tambour doors are an issue remove them and make your own cabinet doors. You can have them done by a cabinet shop if you don't feel up to the woodworking. I would not suggest replacement of all your tambour doors... ie(Overhead storage). This would be very expensive to do and the weight would likely cause other damage issues.The best thing to do if the cabinet is to be completely replaced is to remove it and use it as a template for whatever you build in its' place. The big box stores all can order some custom sized cabinet doors so that the doors would look right for the cabinet and they can be had in many colors and finishes. You may also find something that goes with the look of your other existing tambour doors and color scheme. Hope this helps! Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004
AIR#7110
"My tire was thumping, I thought it was flat!
When I looked at the tire... I noticed your CAT!"
Burma Shave
